997.2 C4S First Impressions
Still plays with cars.
I got my new DD about ten days ago. White with Tan interior.
Key options are:
PDK
Sport Chrono Plus
Sport PASM
PSE
Dynamic Cornering Lights
Bluetooth, Ipod etc.
PDK remains impressive. Depending on what mode you are in, i.e., normal, sport, sport plus, the transmission shifts quickly or in sport plus damn quick - I'd say about as fast as the Ferrari 430 in 'race mode'. Shift quality goes from seamless to slightly brusque but nothing as rude as the Ferrari. In automatic mode it shifts like something from GM, nice. I did notice that slowing abruptly in stop and go traffic occasionally produces a bit of a jolt when the box shifts into first gear. To my surprise the gearbox has a bit of "creep" built in, like an automatic!
After a week I am completely comfortable with the shift paddles/buttons. Different from my 430 but fine once you get used to them. Have not tried launch control - a cute feature but one which I am unlikely to find useful.
Sport PASM lowers the car 20 mm. All I can say is that the car is nearly as low as my 997 RS. I lower myself into it as opposed to getting in.
Having just spent a track weekend with my RS, I can also say that sport PASM in "normal" mode seems to be almost as firm as the RS with PASM set to normal. If you want a cushy ride, I'd avoid the sport PASM option. In sport mode, I can barely tell the difference from 'normal'. That will have to wait until break-in is complete and I can try it on the track.
PSE is wonderful. Engaged it drops the exhaust note by an octave and while driving the car sounds great on a drive-by. Loud enough to be heard but not enough to attract unwarranted attention from cops or sound pressure level meters at tracks with noise limits. It burbles nicely on the over-run too!
Steering is much heavier than my RS, not sure if this is result of the AWD system or not. Not bad, just different. The steering wheel is thicker than the RS in spite of my GT3 having the "thicker wheel" option.
The Bluetooth option works fine, it took about ten seconds to set it up with my Blackberry 8830. It downloaded the phone book at the same time. Haven't tested the Ipod interface, I bought it for resale value. I am an XM radio/Blomberg fanatic and don't own an Ipod.
I do have a few nits. The window switches have mongo springs in them and require about three times more effort than the 997 or 997 RS. They are shaped differently too, with a hollow on the underside which is not well finished. A new supplier I suppose. As usual, they are one touch down but up requires that you hold the button til the window is past half way, then it carries on by itself. I can't understand why they behave that way and I wonder if someone with a PWIS can program that feature out.
The mandatory sun roof is neither one touch open or close, a cheap feature in a car of this price. Hondas have it standard!
The standard Xenon headlights are "brilliant" and the swiveling feature is endearing on dark country roads. It is not as good as the Cayenne which in addition to a swivel has additional lamps which light directly to the side. Too bad, I was hoping for that.
The standard PS2 tires are very noisy on several common paving surfaces, I mean really loud. I don't know if that is a function of the sport PASM suspension or not. The noise level is high enough to be a nuisance in what is supposed to be a business mans express.
Best,
Key options are:
PDK
Sport Chrono Plus
Sport PASM
PSE
Best,
Good synopsis.
i like PDK better than F1, and the floppy pedal criticism is over done (imo). I have used both on the track and each works well. It seems to me that PDK is a better engineering solution than the F1.
I would not hesitate to buy a PDK car, but I just can't bring myself to buy an F1 car.
GT3 player par excellence
CBejbl. You're right. One touch open but not to close the sunroof.
Pics will follow. No camera on this Blackberry
Bob --
Congrats on the new machine. I wanted to chime in and say I am in complete agreement with the road ROAR with the Pilot Sport 2 tires, and Sport PASM. It is absolutely awful in my car here in the pac northwest where they actually use CHAINS in the winter, (what is this, the 50's?) Consequently the roads for 200 miles in every direction have the most horrendous exposed aggregate surface. I have measured it at 105db inside the car at a sedate 60mph. that is LOUD. I want to do a nice roadtrip in the car, but am thinking I will absolutely have to wear earplugs!
I'm in love with my car except for this one, rather large issue.
Michael
Michael
Any one knows if the PSE can be retrofitted? I would love to add one to my car if I can have a PSE switch and control it. Otherwise, I would probably just get the Sharkwerks center muffler bypass pipes.
Thanks.
Thanks.
What is odd is that my 997.1 was one touch open AND close.
Congrats on your new toy.....as a former C4S owner they are fantastic DDs.
