Carrera S II wheel offset
Old Dec 29, 2008 | 06:51 PM
GreggT's Avatar
GreggT
Default Carrera S II wheel offset
What is the Offsets for the S II wheels?
And .... anyone adding spacers to these yet (C4S) ... pics?
TIA
Old Dec 29, 2008 | 10:47 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Sadly, there aren't offset and width markings on the second gen. 997 wheels. I would imagine that they have not changed from the first gen. wheels.
Old Dec 29, 2008 | 10:55 PM
cello's Avatar
cello
TIA
My Dealer took a couple of 09s to a track event it sponsored this summer fitted with the Porsche 5mm spacers. Looked good. The only pic I have of it does not show the rears unfortunately. The spacers did fill out the 4's wheel wells tho (compared side to side).
Old Dec 29, 2008 | 11:49 PM
Paul523's Avatar
Paul523
Sorry Gregg T, no pics or useful offset info here...except that without a doubt the 4/4S models look better with spacers.
I saw several '09 C4 and C4S recently; although 5mm is only a fraction of an inch, the absence of spacers make the rear wheels look noticeably inset into the C4 body's huge rear fenders, at least to my perception. (difference in perception with/ without spacers may not be obvious in photos either).
Old Dec 30, 2008 | 09:54 AM
GreggT's Avatar
GreggT
Thanks for replies ..... when I get the offsets I will share.
Old Dec 30, 2008 | 04:43 PM
GreggT's Avatar
GreggT
Here we go.
The 19 X 8s are ET 57 (w/235/35s)
The 19 X 11s are ET 51 (w305/30s)
I took pics at dealer .... rears definately need significant offset reduction ..... fronts some.
And boy ..... it's had to believe how high the 10 mm PASM suspension is .... looks like it could come down at least 20-25 mm.
Old Dec 30, 2008 | 05:13 PM
KeninBlaine's Avatar
KeninBlaine
Here we go.
Those must have been on a 4S, as they are the same as the 997.1 4S offsets. I expect the narrow body wheels will be the same too, at 57mm and 67mm front and rear respectively.
Old Dec 30, 2008 | 05:22 PM
GreggT's Avatar
GreggT
This is the new Carrera S II wheel on a C4S ..... OE no spacer.
As I recall .... the 997.1 Carrera Sport rear wheels got 17mm spacers from the factory 'to work' on C4s and Targas (i.e. a narrow-body wheel, made to fit widebodies & save AG coin)
Someone correct me if I am wrong on this.
Old Dec 30, 2008 | 05:31 PM
KeninBlaine
Absolutely correct. I have the Carrera Sport wheels with 67mm offsets and 17mm spacers on my T4S. This is how it came from the factory.
