engine reliability of 997's
Old 03-21-2009, 01:06 PM
  #31
Ray S
Ironman 140.6
Ray S's Avatar
Originally Posted by ds2k1
My '06 C2 has >47K miles on it. Zero engine, tranny, clutch, brake issues of any kind whatsoever. This car has been friggin' perfect. Additionally, zero oil leakage on the garage floor. Truly wonderful car.
Happily, I can report the same for my '00 986 and my '02 996..
Old 03-21-2009, 03:34 PM
  #32
ADias
ADias's Avatar
Originally Posted by Kurt_OH
Check out this video of 997 engine testing during development:
http://www.youtube.com/watch?v=fv53RbvgfGc
Just to note that that is the new 9A1 engine released in the new '09 models. This is a totally new engine with DFI and 40% fewer moving parts. And BTW it is at this point totally unproven...
I agree w/ Dan, the M96/M97 engines do not have any more problems than any previous 911 series engine - just different issues. And yes its issues have been blown out of proportion on Internet forums.
Old 03-21-2009, 05:33 PM
  #33
Likemystoppie?
Likemystoppie?'s Avatar
+1 million!!!
See my comments in the guys thread about engine failure.
Old 09-27-2011, 10:35 PM
  #34
WANTED911SC
3rd Gear
WANTED911SC's Avatar
The PORSCHE 997 Engines that are normally aspirated for 1999-2002 are very troubled. I know first hand that a PORSCHE Dealer would have several engines on hand for the poor customer to limp in with their prized 911. I dont think that PORSCHE did their homework - plain and simple. A PORSCHE mechanic that I know told me to stay away from any engine that wasnt derived from the TT IF i must get a water cooled porsche.
911 Air Cooled Cars RULE
BRING IT BACK
Old 09-27-2011, 10:57 PM
  #35
USMC_DS1
USMC_DS1's Avatar
I'm coming up on 49K with my '08 997.1s. It sat at a p-dealer for 4-5 months before I bought it... so leaky RMS at 46K was replaced under warranty. This is to be expected when it just sets there. Other than the RMS seal it was all standard stuff on the service records - oil changes, replacement windshield due to rock damage, etc. Good so far.
Old 09-27-2011, 11:42 PM
  #36
acao
acao's Avatar
No such thing.
Old 09-27-2011, 11:59 PM
  #37
simsgw
simsgw's Avatar
BRING IT BACK
So you resurrected a two-year-old thread to offer three misstatements in one paragraph of four sentences? Wow.
Gary
Old 09-28-2011, 07:36 AM
  #38
gota911
Newbies Hospitality Director
gota911's Avatar
Gary
He must be a BMW Troll and pissed off because he has to drive on "run-flat" tires!
Old 09-28-2011, 11:39 AM
  #39
utkinpol
utkinpol's Avatar
Gary
you know, when i speak to my mechanic he says it in the simple form - any car should be treated as a disposable. STILL, he says, all newer cars are not what older hand made models like 968, 993 used to be - 996 and 97 cars with age develop so many issues that restoration becomes illogical. car simply falls apart. like $30K repair on a 968 car will make it go another 50K miles at 100K miles point - on a newer cars quality of materials and amount of issues does not warrant that.
same with engines - it is pointless even to open up m96 or m97 motor, they all just discard them as it is cheaper to buy another one for $16K (considerinng that you have a core to supply) then to try to repair it.
i find it utterly ridiculous but it is where prices went. $6K is a labor cost just to drop off and put back an engine. i seriously consider now to invest into my own lift for my garage as i do not want to discard my car and i do not think i will be able to sustain pro mechanic rates when car will need new axles, some engine work like blown gasket, etc.
like right now i`m doing major 50K maintenance as my clutch went south - clutch work is 2k, plus new flywheel 1K, plus car gets new AOS, RMS. plus i put in Guards TBD - that alone probably will get to $3K total. none of that I can do in my garage as i have no lift, nothing of that is difficult to do, well, may be with exception of installing TBD into transmission as it requires skill and some precision tools or you`ll kiil ring and pinion.
i used to take engines apart, it is all doable stuff, but, well, labor prices on p-cars went totally crazy. only way for an average person not to be hit with this crap is to sell car away as soon it gets off warranty.
to speak of original question of engines - it is no doubt, m96 and m97 engines are crap. IMS issues happen on all years. my engine now has slow coolant leak on left side head. there are possibilities for numerous internal issues, crankshaft, rods, rod bolts, cracks on cylinders (6th usually), sleeves...
all in all i very seriously consider finding a spare motor somewhere for peanuts and learning to work it. with a lift it is not such big of a job for 2 guys to swap an engine. it is all doable. and i do not want to shell out $20K for new motor if it can be avoided.
Old 09-28-2011, 11:51 AM
  #40
Weissach
Weissach's Avatar
If you look around at the local classifieds, you'll see many 996's/boxsters stating that the engines have been replaced. Many are rollers(no engine). This is NOT normal...and it's certainly not limited to just some guys posting on web forums...
Old 09-28-2011, 11:54 AM
  #41
Weissach
Weissach's Avatar
BTW, you can't compare it to a 928's and 993's.. Those are cars that if taken care of, will outlast their owners..
Old 09-28-2011, 11:59 AM
  #42
utkinpol
utkinpol's Avatar
older boxsters are total disaster and that is why if you lok at prices used 2.5L boxster engines cost like in $3K area. a guy i know got his 2.5L blown at last NHMS event. now he puts in 3.4L 996 motor which was re-worked by racing shop so hopefully it will run reliably for some time.
m97 motor did cost much less than GT3 motor for a reason, but, again, no matter what motor you get, if you run it at 7K-8K rpm for long enough time you cannot expect it to last forever like a camry V6 that almost never gets above 3K rpm in its lifecycle. or a diesel. it is a racing engine and it has limited lifecycle, still, amount of shortcuts porsche did in m96/m97 is disasterous. 9A1 new 997.2 motor supposebly should be mostly free of those things, but, how do you know? it was just 2 years from '09. as most of cars will start getting to 50K miles range it will become more obvious how good rods and othe internals in stock street 997.2 9A1 motors are. But so far i do not think we had a single incident reported on any of p-cars forums, i mean related to a blown engine in a 997.2 car. and it speak volumes compared to amount of m97 enginnes that can go at 15K miles, 30K miles, 40K miles, literally any time when they feel like it.
Old 09-28-2011, 12:01 PM
  #43
utkinpol
utkinpol's Avatar
well, to speak of that, most 993 cars need valves to be replaced close to 60k miles, and engine work on those cars is VERY expensive. that was one of major reason for me to forget about getting RS america car for racing, actiually, after i learned how much exactly you have to pay and how often for its motor to be refreshed.
so newer engines are not worse in all regards. most of issues were caused by 'cost reduction' items like replacing suppliers they had for ages with 'cheaper' ones with QA issues, replacing forged parts with cast parts, as usual - marketing people who come to 'increase profits' kill a good product.
Old 09-28-2011, 12:02 PM
  #44
jakes dad
jakes dad's Avatar
I know it's been asked many times before but.... what is the cost of a total engine failure???
What's the worst case scenario? engine, install and associated items required to put you back on the road?
I'm talking about new parts from Porsche..
Obviously I'm looking for a ballpark figure... 15K 20K???
Old 09-28-2011, 12:11 PM
  #45
utkinpol
utkinpol's Avatar
it depends. i just spoke to my mechanic about this. if you want to buy brand new M97 X51 motor with no discounts - it is $40K or so.
standard M96 motor costs $16K assuming you have a core to give back - means usable non-cracked motor base. on top of that you will have labor - about of $6K probably to swap motor out.
when you deal with dealers you may get some discounts, in average ( I THINK ) I saw figures like in case of IMS failure ona car out of warranty when dealer covers part of labor and part of engine, like 20% and it ends up with $10K-$13K for motor and like $2K-$3K for labor. I also saw samples of total bills for this work - usually it is close to $20K one way or another, people who get total thing done close to $15K are lucky ones. that is with new crate from Porsche. Other way is to shop around (creatively) for remanufactured/restored usedm96/m97 motor. Those usually cost around of $9K or so but obviously you get an another granade ready to explode when it will decide it is its time to blow.
Dealer discounts apply usually only if engine went down due to something related to known problems with motor design and PCNA agrees to honor i which is also not guaranteed. Anything like that with Toyota or honda would cause class action long time ago, but with luxury brands - well, I honestly think best thing for any M96/M97 motor owner to do is to upgrade to car with 9A1. It is way better way to invest $$K than to pay for another m96/m97.
Quick Reply: engine reliability of 997's
