My car eats nails
Old Nov 16, 2008 | 08:57 PM
OneManTX's Avatar
OneManTX
Default My car eats nails
Screws, bolts, whatever. Third one in maybe 3 months, same tire (right rear). Should probably be patchable again. (The second nail apparently wasn't all the way through, so the tire only has one patch so far).
File Type: jpg
Old Nov 16, 2008 | 09:01 PM
ADias's Avatar
ADias
Patchable no doubt. Watch where you drive, namely the right side and avoid speeding near construction zones.
Old Nov 16, 2008 | 09:42 PM
cviles's Avatar
cviles
Unique Title
Debris tends to accumulate along the sides of roads -- if you "miss" a few more apexes on the street you might save your tires.
Old Nov 16, 2008 | 11:06 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It seems that my tires were particularly attracting nails, etc. during certain times,--when they were quite new, and with only a few thousand miles on them. It seems that they attract less when they get more worn,--don't ask me why. The right rear (for us in the USA) is usually the one most likely to take the hits.
Old Nov 17, 2008 | 02:07 PM
cole328's Avatar
cole328
my mechancic told me the right rear is the most prone as it is on the inside near the curb, where debris accumulates ALso, something about the "exact" speed of the car is what makes it more prone...if you hit the sweet spot on speed, a) the front tire straightens it up, and then b) the rear tires gets puntured for some reason, this sweet spot speed is in line with that experienced in parking lots (as opposed to highway speed)
Old Nov 17, 2008 | 02:32 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Often the front tire flips up the debris,--and the second tire over it strikes it
Old Nov 17, 2008 | 04:12 PM
ajayabb's Avatar
ajayabb
Sounds like a job for MythBusters!!!!
Old Nov 17, 2008 | 04:52 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Actually, we did a POLL on Rennlist about 18 months ago and factoring out the UK drivers with their steering wheels on the other side, the RR tire was the one taking the majority of the hits.
Old Nov 17, 2008 | 05:20 PM
MikeBat's Avatar
MikeBat
Count me in on right rear. No flats for 10 years... twic ein 2 months, both on same right rear tire.
Old Nov 17, 2008 | 07:18 PM
ds2k1's Avatar
ds2k1
3 nails in the RR in 2.5 years. 2 of them were unpatchable. Last time, got less than a month on the new tire.
Old Nov 17, 2008 | 07:24 PM
sharmat's Avatar
sharmat
+1 RR for me 2 months ago. Never thought about the RR as most prone to nails before. Happened on a new tire with less than 500 miles.
Old Nov 19, 2008 | 06:27 PM
InTheAir's Avatar
InTheAir
That's strange. I recently had a nearly identical looking screw (hex head with flange) embedded in my front tire. I had to unscrew it to get it out.
Old Nov 19, 2008 | 11:08 PM
OneManTX's Avatar
OneManTX
Makes you wonder how they get in there ?!
Old Nov 20, 2008 | 12:28 PM
InTheAir's Avatar
InTheAir
Thankfully for me, it was in the meat of the tire and was short enough that when I unscrewed it, the tire held pressure.
Unfortunately, I had already replaced all four tires with my snow tires believing I was going to need to bring these wheel elsewhere for repair.
