K&N air charger install
I purchased the K&N air charger kit from vividracing for my 997 c2s. K&N does not list this kit for the 997,only 996. The rep at vividracing said that they have sold hundreds of these for 997's. Anyway, there is a small hose that runs on the back (engine side) of the stock air box and connects to an inlet to the airbox. Beings as this system was not made for 997 there is no direction on what to do with line on the conversion. It appears to be a vacuum line (for the tiptronic?). Vividracing rep did not know what to do, either.
Any advice out there?
Jean-Claude
Jean-Claude
My comments aren't intended to be smart aleck or demeaning but honestly, my advice is to take it back to Vivid and get a refund. If K&N doesn't list the part as a fit, then it's probably not going to fit. And if Vivid's own rep. can't help, I think you've been sold a bill of goods.
Get a refund.
Jean-Claude -
Get a refund.
Get a refund.
Jean-Claude
Jean-Claude
Plug it and forget it. Or take the line off and cap it on the manifold with a rubber cap available at your local auto parts store.
IMO I dislike Oiled filters like the K & N because of the Oil. It can get on your MAF sensor.
The vacuum line controls a variable resonator for the airbox. This is strictly a noise control device and will not effect the drivability or durability of the vehicle as long as it is properly and completely plugged.
That being said, I have to say that the MAF sensor (an expensive bit of kit) is likely not validated to be robust to the oil amount used on the K&N element. We have already seen failures of that sensor on rennlist when aftermarket systems are installed. Furthermore, the running joke with the engineers who design and develop the OEM (original equipment manufacturers) systems is that K&N is good at keeping rocks, golfballs, and birds out of your engine, but little else. You might gain a tad of HP with the K&N system installed, but at the expense of long-term engine wear. If your cool with that...
A sponsorship sticker on a race car is not evidence that it is a good idea to install it on your engine.
When you use the the phrase " why in the world would you"........and you offer no advise: it IS smart aleck and demeaning. Look at the preceding post, he gave advice rather than just criticizing.
To answer your question, I converted my mustang cobra to a similar system and had dramatic improvements in low to mid range torque. I was looking for the same in the Porsche.
Jean-Claude
Send that POS K&N back to Vivid and get the EVOMS cold air kit if you are looking for more intake sound. The EVOMS kit uses a dry filter element so that the MAF sensor does not get ruined. The Koni Challenge Porsches use the EVOMS kit. The stock air box is already a excellent flowing cold air box anyway. The K&N so-called cold air kit breaths in hot engine compartment air. YIKES!
I have not seen the EVOMS kit mdrums mentions, but one common fault with cold air kits is that they frequently ignore water splash. If you are strictly a sunny day driver, not to worry. However, if you happen to be caught out in a storm and unexpectedly drive through a semi-flooded section of roadway - there is a chance to hydrolock the engine and the result is HUGE engine damage. OEM systems are all tested for this possibility.
Again, might not apply to the EVOMS system mentioned, but be sure. Racing use does not validate this concern as they would not be racing if there was 5-6 inches of standing water on the track.
