Inconsistant Oil Readings?
Had my 08 out today.Checked the oil 3 times.First time seemed like I was a 1/3 low, so checked again on very level surface.This time came up about 3 lines low.Thought this was unusual but not impossible have 1300 on car and only added 1/4 quart at 300 miles)So checked it again and read just about full several times as I thought I left it last time I drove a few days ago.
Anyone else get varied readings on the dash read out.??
Give me a dip stick!
If you do a simple search on the 997 forum you will find substantial discussion already on this exact subject.
Oil mileage varies considerably, from no usage at all to a quart every 500 miles.
Pick a level spot and just keep watching it. Don't add oil until you have seen that it is truly low. I used to add oil only when the bottom block was flashing. (Then it takes one quart).
I got 3 different readings just today. Maybe that's because I cranked the car on 3 different occasions, but I do just what Dan mentioned. I just keep watching the oil levels until I get a consistent reading over several days. Only then do I confirm the location of the extra quart of oil in the garage.
For more info see here: (Thanks Joe.
)https://rennlist.com/forums/showthre...85#post2727985
https://rennlist.com/forums/showthre...32#post2730032
And here:
https://rennlist.com/forums/997-forum/248530-oil-consumption.html
https://rennlist.com/forums/997-forum/222078-oil-consumption.html
Hi,
Yes I have different readings all the time. I usally wait till it's low and add 1/2
quart. I had it blink once and I added 1/2 quart and it showed 3/4 on
the reading gage. I park the car on a hill so I expect some weird
results.
Paul
results.
Paul
