Battery Tender light goes off after 5 minutes
It's winter and I'm not using the Boxster much. Why does my battery tender light go off after about 5 minutes? I've got the "Porsche" brand tender that goes into the cig. socket. Does it mean the battery is full or what is the problem?
Bruce
Bruce
I have the latest Porsche tender (purchased in October,07)...orange light glows when the device is on and the other (charging) light changes from red to green but is always on.
On a related note, has anyone had battery fluid drain out the bottom of the car onto the garage floor when the tender is in use? I have and believe it was due to my overfilling the battery with distilled water.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Uh, yeah.
My OEM battery did this while on the maintainer. And it was not from overfilling with distilled H2O - it was from underuse - one or more of the cells "sulphurated" - fancy word for self-destructed - while in storage. The problem is for underuse, of which I'm very guilty. These batteries need to be used. In fact Porsche won't warrantee them unless you drive the car at least 6K miles/year. I started a thread on this over a month ago on the 996 board.
I would have gone with an Optima or something comparable also, but I thought the battery would be covered under warrantte - it wasn't due to the low miles on my car. Porsche requires 6K miles/year - so I just had dealer install another OEM. Next time, I'll know.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
From what I have been told a lot of companies in the aerial lift/work platform rental business use the stuff. We don't do aerial. I am probably going to try some in a couple of solar powered variable message signs. The batteries in them tend to sulphate after a while and because of that we have to put them on charger every so often to knock the crap off the plates. If this prevents this it would save us a lot of dough.
