Over inflate tires for long sit?
I just drove my car for the first time in 6 weeks. Bad weather combined with Christmas Travel. The first 10 miles sucked as my P Zero's were very flat spotted.
Would over inflating the tires prevent this from happening so badly?
Any downside effects to temporarily over inflating the tires?
I always over-inflate my tires during winter storage of 4 months. Inflate to about 3 to 5 psi below maximum allowance of the tires. Upon re-start in spring, just drain them back to recommended driving pressure. I don't even bother "moving" the car inside the garage for the whole winter.
The 996 manual says (and I'm guessing the 997 is the same):
"Increase the tire pressure to 58 psi. It is not recommended to lift the vehicle, due to the possibility of corrosion on shock absorber piston shafts.
The vehicle should be moved slightly, approximately every four weeks, to prevent flat spot on the tires."
Many people think the P Zeros flat spot more easily than Michelin PS's, but I've had both and have never had trouble with the P Zeros flat spotting even after a couple months. I do increase the pressure and move the car a few feet every few weeks, though.
If you wanted to do this, you have to remove the wheels and put a axle mount stand on each one and let it rest on this. This loads the suspension correctly, no exposed shock pistons and no undo stress.
As for overinflating, they ship the car from factory with 60LBS in the tires. This keeps them from flat-spotting when sitting for some time.
I use Tire Cradles AND I over-inflate.
Regards,
Deanski
Not a good thing to do. You're exposing the shocks and the piston rods to rust, and put undo wear on any suspension part hanging as it was not designed to do.
Regards,
Deanski
Regards,
Deanski
This topic comes up every once in a while and the ideal answer is always the Tire Cradles. Some people are put off by the cost, but if you look at the labor savings (no fussing with air pressures) and their useful life (they will serve you through car after car). they make the most sense.
Go for it.
Go for it.
