smartTop
Old Nov 4, 2007 | 12:27 AM
kevinrubin's Avatar
kevinrubin
Default smartTop
OK...this is my first cab...IT IS AWESOME.
I have looked in the manual and the top doesn't seem to be "one touch." I know the boxter will open with "one touch" over ~ 6 mph...my 997 doesn't seem to do that and the manual mentions nothing of it...
So...I have been reading a bit about smartTop...there appears to be good feedback from this forum.
Anyone install one on a 997? What is a reasonable cost? Is it a "do it yourself?"
Thanks.
Old Nov 4, 2007 | 04:04 AM
kw_1055's Avatar
kw_1055
It is a do it yourself, 20 min. job.
If I remember correctly, it's about $700 but check their web site.
I like it. The one touch is almost enough to justify the cost.
The remote open/close function is also great.
You can also program the car to beep when remote lock etc.
Old Nov 4, 2007 | 11:38 AM
Maison's Avatar
Maison
Agreed on the DIY. It's only $479 now and free shipping, but since you in CA you'll have to pay tax. Mine came to about $520 and got it a day later since they're nearby. Love the one touch, autolocking, and beep when locking/unlocking.
Old Nov 4, 2007 | 01:52 PM
nomo16's Avatar
nomo16
+1 I love it
Old Nov 4, 2007 | 02:00 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
It's the best modification for a 997 Cabriolet, hands down. It installs in minutes, adds lots of custom features (e.g., remote opening, closing, hood opening delay, headlight remote turn-on and shut down, one touch opening/closing (critical for those with 6-speeds and only 2 hands) etc.)
Periodically they run a deal on Rennlist if you get enough interest to do a group buy. It's been some time so it's worth a try.
It can be turned off quite easily before you drop the car off for servicing if you're concerned that they will 'discover' you've modified the car. The features should have been offered in the USA model but our litigious society has dictated much of the design for Porsche.
Old Nov 4, 2007 | 04:51 PM
MichaelL's Avatar
MichaelL
I had the SmartTop installed on my car. It worked great until it failed catastrophically. The horn was blasting and the top wouldn't go up. The battery had to be disconnected. Had to have the module removed & the top reset. Luckily, the car wasn't damaged. Warranty for affected parts would have been void. Lost 5 days of use. The manufacturer(Wilhelmy) was unapologetic, uncaring and less than helpful. I was out the cost of installation, removal and two way shipping. Aftermarket manufacturers like this are nothing but a detriment to the automotive community. Do business with them at your own risk.
Old Nov 4, 2007 | 10:42 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
I would say that Michael's experience is rare and would not let it detract from getting it. It's been flawless since I put it in myself.
Old Nov 5, 2007 | 10:33 AM
limey940's Avatar
limey940
Im interested in a smart top, is it worth seeing if we can get a group buy togther?
cheers
Old Nov 5, 2007 | 11:49 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
cheers
Post this with the corresponding forums,--997, 996, Boxsters, etc. Now with the turbo Cabs, post under turbo as well.
Good luck!
Old Nov 5, 2007 | 12:10 PM
1Carnut's Avatar
1Carnut
Mine has been great too. No problems at all.
Old Nov 5, 2007 | 01:46 PM
limey940's Avatar
limey940
Will do, thanks dan
Old Nov 5, 2007 | 05:10 PM
ramans's Avatar
ramans
+1 for a group buy
Old Nov 5, 2007 | 09:32 PM
MichaelL's Avatar
MichaelL
I am perfectly willing to accept that the Smart top unit works effectively and as promised most of the time. Mine, however, did not. Its failure could have caused significant damage to the car. It was just new on the market when I purchased it and one would think that the manufacturer, Wilhelmy, would have treated this incident with all due concern. This was not the case. They were not legally obligated to recompense me for my incidental costs, but a simple apology would have gone a long way.
As a customer, I resent being treated with indifference and do not want to deal with anyone who does not make an effort to get things right. The true measure of a firm is how they perform when something goes wrong and Wilhelmy clearly failed here.
Old Nov 5, 2007 | 10:20 PM
Paladin's Avatar
Paladin
I have the SmarTop in my cab and have had nothing but a good experience. Based on that experience I recommended and installed it in a friend of mine's 997 cab. His driver side rear window is now permanently stuck in the up position. This may not be a defect in the SmarTop as the issue remains even with the SmarTop in pass-through mode and he hasn't had a chance to remove it yet. However, when I spoke to Wilhemy for support they were disinterested in even feigning an attempt at assistance and referred me to the latest version of the rather spartan on-line manual. My friend will be bringing his car back to the dealer for what I hope is a simple reset.
I would still recommend the SmarTop as a great mod for a cab, however now with a caveat regarding my support experience.
