Southern California Fires
Poseur
The real problem today with homes facing these wind-whipped fires are the eaves of the houses. Most today have fire-resistant roofs, but with the Santa Ana winds blowing these things into the SIDES of the house the flames start licking at the eaves of the roofs and then it's all over. Years ago I had a new roof put on my place,--Alcoa "Cedar Shakes." I asked my home insurance company if I would get a reduction in my premiums for a fire-proof roof and their response was that most home fires don't start on the roof. Those of us in California would find that hard to believe! Here was my pool on Sunday morning,--this was simply ash and dust from 36 hrs of high winds that brought this stuff in from this summer's fire to my north. The new stuff coming in from this current crop of fires is contributing little.
Stay safe!
Stay safe!
Extensive coverage here with lots of pics:
https://rennlist.com/forums/off-topic/386598-socal-fire-storms-all-discussions.html
Guest
Posts: n/a
Good to know. A friend who lives out there just sent me this:
Concrete Homes Stand Up to Earthquakes
Built according to good practices, concrete homes can be among the safest and most durable types of structures during an earthquake. Homes built with reinforced concrete walls have a record of surviving earthquakes intact, structurally sound and largely unblemished.
In reinforced concrete construction, the combination of concrete and steel provides the three most important properties for earthquake resistance: stiffness, strength, and ductility.
Why Buildings Survive
Scientists study damage from earthquakes to determine what types of buildings best withstand seismic forces. Modern earthquake-resistant design relies on several recent studies:
Year Earthquake Magnitude Studies
1989 Loma Prieta 7.1 University of California, Berkeley
1994 Northridge 6.8 NAHB Research Center / National Institute of Standards and Technology
2000 Yountville/Napa 5.2 Stanford University
Studies of earthquake damage consistently show well-anchored shear walls are the key to earthquake resistance in low-rise buildings.
Optimal design conditions include shear walls that extend the entire height and located on all four sides of a building. Long walls are stronger than short walls, and solid walls are better than ones with a lot of openings for windows and doors. These elements are designed to survive severe sideways (in-plane) forces, called racking and shear, without being damaged or bent far out of position. Shear walls also must be well anchored to the foundation structure to work effectively. Properly installed steel reinforcing bars extend across the joint between the walls and the foundation to provide secure anchorage to the foundation.
Why Buildings Fail
Low-rise buildings most vulnerable to earthquakes do not have the necessary stiffness, strength, and ductility to resist the forces of an earthquake or had walls that were not well anchored to a solid foundation, or both. Three types of buildings sustained the most significant damage:
Multi-story buildings with a ground floor consisting only of columns:
Most of these buildings were 3 to 4 stories tall with a parking garage or a living area with many large windows on the ground level. The columns may have been strong enough to hold up the structure, but did not provide an adequate amount of racking resistance during a seismic event. When the earthquake shook the building side-to-side, the upper stories sometimes tipped over to one side. Whether built of wood, steel, or concrete—they all suffered damage.
Wood-frame houses with weak connections between the walls and foundation:
Wood-framed buildings are inherently ductile (flexible), which is an attribute during an earthquake. However, the shaking sent some of these houses sliding to one side. Frequently, the shear walls were strong enough, but the connection to the foundation was a weak point that gave way.
Un-reinforced masonry or concrete buildings:
Masonry or concrete walls not reinforced with steel bars were not ductile enough to be effective shear walls. And if there is no steel connecting them to their foundation, the joint between walls and foundation can be a weak point.
Why reinforced concrete is safe
Reinforced concrete walls are a composite system: Concrete resists compression forces, and reinforcing steel resists tensile forces produced by an earthquake.
The concrete is cast around the bars, locking them into place. The exceptional ductility of the steel to resist tensile forces, coupled with the rock-like ability of concrete to resist compression, results in an excellent combination of the three most important earthquake resistance properties: stiffness, strength, and ductility. A study at Construction Technology Laboratories revealed that even a lightly reinforced concrete shear wall has over six times the racking load resistance as framed wall construction.
It’s no wonder that modern reinforced concrete buildings were found to survive these recent earthquakes with rarely any significant damage.
More Information?
Comerio, Housing Repair and Reconstruction After Loma Prieta. University of California, Berkeley.
Miranda, Aslani, and Blume, Brief Report on the September 3, 2000 Yountville/Napa, California Earthquake. John A. Blume Earthquake Engineering Center, Stanford University.
National Association of Home Builders Research Center, Assessment of Damage to Residential Buildings Caused by the Northridge Earthquake. The United States Department of Housing and Urban Development, Office of Policy Development and Research, Washington, DC, July 20, 1994.
Todd, Carino, Chung, Lew, Taylor, and Walton, 1994 Northridge Earthquake: Performance of Structures, Lifelines and Fire Protection Systems. Building and Fire Research Laboratory, National Institute of Standards and Technology, Gaithersburg, MD, March 1994.
Why Buildings Fail
More Information?
You're right it's the nut jobs that start them. I'm not sure what the penalty is for it but it sure needs to be stiff.
Guest
Posts: n/a
Are these fires ever caused by people flicking their cigarettes out the car window (we have alot of people doing that in S Fl and it irritates the $hit out of me!)?
Poseur
I had a fire get too close to my house for comfort a few years back in Laurel Canyon because of an errant butt.
