TPMS
Old Jun 23, 2007 | 09:58 PM
rfedele's Avatar
rfedele
Default TPMS
Does anyone know of aftermarket sensors that will work with our system?
Does anyone know if other OEM sensors will work? I see many (Ford, Dodge, Toyota, etc.) on Ebay. They all look similar.
Any issues to be aware of on mounting? They will go on a set of turbo twist.
Dealer quoted me close to $1K for 4 sensors for my winter set (previously used on 05 C2S w/out TPMS). Seems I'm already thinking of snow.
Old Jun 25, 2007 | 10:53 AM
99firehawk's Avatar
99firehawk
porsche uses a a 433mhz signal other 433 mhz signal sensors should work but, i cant promise anything
Old Jun 25, 2007 | 11:36 AM
SB's Avatar
SB
Tire rack sells TPMS sensors for under $100 a pop.
Old Jun 25, 2007 | 12:32 PM
jhbrennan's Avatar
jhbrennan
You can buy the Porsche OEM TPM sensors for that price too.
Old Jun 25, 2007 | 12:34 PM
jhbrennan's Avatar
jhbrennan
I'm assuming you already have the TPMS system as an option (MY06) or original equipment (MY07) - if you don't putting sensors in the wheels won't work since you need the receivers in the wheel wells plus all the wiring, electronics, etc.
Old Jun 25, 2007 | 12:55 PM
rfedele's Avatar
rfedele
Thanks for all the responses so far. I do have the system already MY07.
What happens if you run the car without the sensors in the wheels? I assume it keeps giving annoying warnings and beeps. I doubt I would run it that way, the sensors did save me from running on flat. Even after I got the warning and inspected the tires I couldn't tell it was low and the pressure had dropped to about 20PSI.
Old Jun 25, 2007 | 01:00 PM
SB's Avatar
SB
I believe they are OEM.
Old Jun 25, 2007 | 02:18 PM
99firehawk's Avatar
99firehawk
you can turn the system off, it will beep once on start up and the lightg will always be on
Old Jun 25, 2007 | 03:23 PM
rfedele's Avatar
rfedele
from where please?
Old Jun 25, 2007 | 03:37 PM
jhbrennan's Avatar
jhbrennan
from where please?
Try contacting the guys at Sunset Imports - www.sunsetimports.com
Old Jun 25, 2007 | 03:58 PM
brad@tirerack.com's Avatar
brad@tirerack.com
Former Vendor
Porsche uses Beru as their vendor up through 07.
The sensors we sell are the same ones Porsche uses. There are only a handful (6) companies making them for everyone. The manufacturers are buying from the same pool of available vendors. I guarantee ours are the same ones that an OE wheel will have - just sold at a much better price than the dealership.
