RMS Question
#46
Originally Posted by cdodkin
Interesting - search for rms fail in the 996 GT2/GT3 forum - you get two hits, non of which are rms failures
Do the same in the 996 forum, you get 85 hits.
That tell you anything?
The 996 GT3 cars use a 964 derived crank case so they don’t suffer the same probs as the later designed 986 (boxster ) & 996 cases & cranks,
i.e. they use the earlier designed conventional rotary seal not the hard plastic RMS which fails.
So the very very few RMS failures in these cars should not be confused with the general 996/986 RMS failures.
It's not the same deal, not the same part, not the same issue.
I agree with you that it does not seem as prevalent with the GT1 derived Turbo/GT2/3 engine.
#47
Originally Posted by OCBen
Show me where I have ever proclaimed myself 997 Forum leader and I will gladly paypal you $100.00. Should be pretty easy for you if you are in the habit of speaking the truth. But if you were lying again this will prove to the thousands here that you indeed are in the habit of posting misinformation, and shouldn't be trusted. And this little challenge will be an excellent proof of that.
What happened at that favorite forum of yours? Did they finally catch on to you?
I'll deliver us$1000 ($100 is nothing) to you IN PERSON if you read the following which will help you understand your uniqueness and "leadership" role here:
________________________________
We need to realize that there is another group which I would term as "online bullies" or "internet bullies" who can become equally destructive in undermining communities.
These gentlemen/ladies differ from trolls in the sense that they are not anti-social, but they are an accepted and sometimes
well-respected members who assume a sort of informal and unofficial leadership role.
They use this position to intimidate and assert their views on newer and less established members and often push their weight around to mark territorial rights. They will generally try and behave properly, but subtly try and behave like moderators and preach about forum behaviour. They will also turn and insult people as they wish and surprisingly other forum members will turn a blind eye to them.
They will usually "adopt" ownership of
a single forum or a subforum of a board and hang out there frequently with their clan. (this feature is usually more common in larger forums)
These people are often the starting point of cliques because they can
gather a group of yes-people around them in no time.
1.Bullies can cause enormous damage to a forum by their behaviour.
2. Bullies usually have excellent communication skills using which they attack their opponents unmercifully.
3. Bullies can be intimidating to any normal forum user.
4. Bullies have the effect of creating bad blood.
5. Bullies are hard to control without intervention right from the top - the forum administrator(s) or owner(s) because even moderators might find it hard to control them without support from others.
6.Bullies are more or less regular forum members who might have a huge post count and a following.
7. Bullies intimidate other members by throwing their weight around and using their group of yes-people to lend force to their powerful attacks.
8. Bullies regular members and they have a huge post count.
9. Bullies enjoy fighting and run around bashing everybody who dares oppose them.
10. The potential damage done by bullies is forum-wide and not related to topics, but to the personality of the bully and the kind of respect and influence he wields.
#48
MMD, are you really going to give OCBen $1000 for just reading the text of your post? There must be a typo in there somewhere. In any case, I am relatively new here, and from the short time I've been participating, I think MMD, OCBen and many others contribute a lot to this forum. I suggest you guys bury the hatchet and move on to more positive things like . . . what was the subject of this thread again?
#49
Originally Posted by PTEC
I still don't get why people **** the bed when they see a 997 with an RMS leak. Early cars were fitted with the old seal, fact. Another fact is the new seal is much, much improved so just take the thing in and have it fixed.
Good thing these are so much fun to drive when they are not in the shop.
#51
Guest
Posts: n/a
Originally Posted by The B
Maybe I can help: I had my RMS replace 3 times in the first 8 mos. of ownership. I was pissy about it because none of my past 60k-110k+ cars ozzed oil on friends driveway (brick) and required me to drive "Smoke infested Nissan Altima rentals" for more than a month of the first year of having it.
#53
Guest
Posts: n/a
Originally Posted by 99firehawk
thats really irevalant, changin t he seal isnt rocket science, any body who can pull the trans and has the tools can chnage the seal
#54
there is no way to mess up a seal instalation, just becasue the seal leaked doesnt make it the techs fault, the rms is not always the source of the leak, the case bolts and the ims also leak, are they changing bith when the fix your leak?
#55
Originally Posted by John NY-Naples
MMD, are you really going to give OCBen $1000 for just reading the text of your post? There must be a typo in there somewhere. In any case, I am relatively new here, and from the short time I've been participating, I think MMD...contributes[s] a lot to this forum.
For some reason he thinks only hobbiests like himself bother to join these forums and he finds it hard to believe that engineers and scientists and technical experts are actually here as members of Rennlist. That's why he appears to have the impression that the more he reads about things on the internet and magazines the smarter he is than anybody else on these matters.
And as you've seen here, as soon as someone points out his inaccuracies he lashes out at them in a vicious mean spirited attack just as he attacked 99firehawk, a noted Porsche technician:
Why don't you correct my "misinformation?" Because _you_ don't know what you're talking about.
I subscribe to and read "Excellence," and "Panorama."
That's where I get my info on RMS.
Do the research and learn about the RMS.
There. Feel better?
There. Feel better?
Why don't you STFU and go attack someone else; maybe find some gang members on a street corner to harrass?
Read my freekin' post and don't misquote me.
#56
Guest
Posts: n/a
#57
How he always tries to manipulate things and make me out to be the bad guy when he is clearly demonstrating sociopathic behavior and himself is a passive aggressive bully.
Re read:-------------------------------------------
These gentlemen/ladies differ from trolls in the sense that they are not anti-social, but they are an accepted and sometimes well-respected members who
These people are often the starting point of cliques because they can gather a group of yes-people around them in no time.
1.bullies can cause enormous damage to a forum by their behaviour.
2. bullies usually have excellent communication skills using which they attack their opponents unmercifully.
3. bullies can be intimidating to any normal forum user.
4. bullies have the effect of creating bad blood.
5. bullies are hard to control without intervention right from the top - the forum administrator(s) or owner(s) because even moderators might find it hard to control them without support from others.
#58
The vast majority of RMS issues have occurred where seals have either worn on the crank, or the crank has sat in one offset position for a long time causing deformation of the seal, and hence a leak. (People who don't drive their cars often!)
CDodkin
Thanks very much for this explanation. I have had two RMS and one IMS replaced so far (car is an 01 996). It is stored winters (Oct to mid-April). This year, I did notice a small amount of seepage immediately after removing from storage and local Porsche tech said that RMS was gone again. I decided to wait (based on good advice from felllow members) and oil seepage has completely disappeared. I suspect that some driving took care of the problem.
Your explanation of a deformed seal due to lack of use makes perfect sense. My thought is to start and run the car regularly (yes, I will get it to operating temperature on the road) when weather permits during the winter, therefore changing crank position.
Thanks again
Cheers
Ian
CDodkin
Thanks again
Cheers
Ian
#59
i didnt read the whole thread but i just love when MMD and OCBEN go at it. LOL! between ocbens misinformation and thinking he knows more than he actually does, and mmd's negative attitude towards everything, its awesome!!!
i expect to get a pm from ben again, lol
#60
Originally Posted by DrDrilZ
i didnt read the whole thread but i just love when MMD and OCBEN go at it.....it's awesome!!!
I'm here all week. ..... Try the salmon this time.
Oh, and don't flatter yourself. You're gonna have to do a lot better
than that if you're hoping for a PM from me.
