AC stopped working; dealer says condenser needs to be replaced on my dime.
#77
Originally Posted by ddub
Does this sound like the same problem that Alan Smithee had?!?
#78
Thanks for the response!
I rarely use AC; whatever punctured my condensor did it when the system was off...no drama as you described. I went to use it one day and it didn't blow cold air...
Thanks, I'll see what the service guys say...
#79
Originally Posted by MichaelL
I just had the Cargraphic screens put on. The radiators picked up quite a bit of trash. The screens look good, but $20 worth of expanded metal mesh was $300. The bumper cover has to come off for the install.
#80
Originally Posted by OCBen
Yes it is.
Any screen in place would restrict the air mass flow rate. A reduction in the air mass flow rate means less cooling of the condenser which leads to inefficient and ineffective operation of the A/C, requiring the A/C compressor to work harder (possibly running continuously) to provide the same amount of cooling as before, thus syphoning away available horsepower from the engine that could be better used in powering the drive wheels.
One option is to make the condenser (or radiator) bigger to compensate for the loss of air mass flow rate that a screen will produce. This then will obviously add to the weight of the car.
It's all about making the right compromises to arrive at an optimum design solution.
