Brake Squeal
Old Mar 5, 2007 | 03:57 PM
Guest
Posts: n/a
Question Brake Squeal
Just starting getting a very low speed brake squeal so I did some hard stops which made it go away for the time being; are 997s's plagued with brake noise?
Old Mar 5, 2007 | 04:00 PM
CharlieJr's Avatar
CharlieJr
Now this, in addition to your rattles??
Have your rattles been fixed?
Old Mar 5, 2007 | 04:39 PM
cvazquez's Avatar
cvazquez
-sometimes brake squeal is nothing more than dust and dirt build up. Take your car thru an automated car wash or hose down the backside of all four wheels for 2-3 minutes each.
-brake squeal is usually temporary and will go away as brakes wear in more.
However, if this issue continues get em check by a P-car tech. It could be rotor, brake backing, anti-noise pad, leaking fluid or defective pads... etc.
Old Mar 5, 2007 | 06:08 PM
elh0102's Avatar
elh0102
Some low speed brake squeal is not unusual, particularly if you use your brakes conservatively. As you noticed, hard use will usually alleviate any noise, for a while. Properly bedding new pads is important, mainly for maximum effectiveness, but it also helps with noise. When I put street pads on after a track weekend, I always spray the back with anti-squeal compound, since I never use the damping pads attached by the factory. Those things will generally eliminate all noise, but they are such a pain in the butt if you switch pads often, I threw them away. The spray works fine for me, but I will have a little low-speed noise occasionally. If you are bothered by the amount of squeal you have, try a set of some of the low noise and low dust ceramic compound pads. For street use they work fine, and are very clean and quiet.
Old Mar 5, 2007 | 06:12 PM
OCBen's Avatar
OCBen
The squeal is supposedly due to a "glazing" of the rotors as a result of "cold braking" effects. This was discussed in depth some time ago.
The solution is as you describe. I used to get that a lot when I had my Boxster. Haven't experienced it yet with the 911.
Old Mar 5, 2007 | 08:27 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Many years ago a girlfriend of mine was into racing Porsches. She used to wait until the last possible second to brake for stop signs (assuming no one was on her tail). If you drive like that for awhile you won't ever have that problem. (I personally have never had that problem because of how I brake,--even less of a problem with PCCBs).
Guest
Posts: n/a
It's first for me in a 911 as well...
Old Mar 5, 2007 | 08:38 PM
Guest
Posts: n/a
I fixed 2 of the three myself and the dealership seems (knocking on wood as I hit my head) to have fixed the one's coming from the rear of the car. The repair was felt tape (where would Porsche be without this stuff) under the bottom of the arms/hinges to the engine lid. The rattle I had sounded like something was very, very loose where the slightest bump would set it off, I also heard a squeaking (like swinging a metal bucket back and forth from its handle) coming from the rear on hard left turns. It's very difficult for me to imagine this was the area causing these issues as there was almost no clearance or room for such a rattle/squeak to emanate in the first place, but the noises seem to have been vanquished. I wonder if sometimes a repair is listed a certain way when in fact it was something else and reported differently or only part of the fix?
Old Mar 5, 2007 | 09:40 PM
Guest
Posts: n/a
Thanks for the feedback guy's. As I mentioned above in response to Ben's post, this is a first for a 911 with me; it came on today with no trace of prior noise and was quite loud from time to time; tomorrow I will give the brakes a good workout and see what happens.
Old Mar 14, 2007 | 12:54 AM
Guest
Posts: n/a
I flushed the brakes (when cold of course) about a week ago and so far no more noise. Sure hope it stays this way and thanks.
