Front seat removal
Can anyone help me with front seat removal? Just looked under the front seat have no idea where to begin. Wanted to install a Fire Extinguisher. Any hints? I couldn't find any posts on it.
I went through this myself and ended up having it done at the dealer for 1 hour labor.
https://rennlist.com/forums/997-forum/286509-any-pictures-of-porsche-fire-extinguisher.html
http://www.rennteam.com/showflat.php...rue#Post297908
Yeah, I was that and will probably go with your set-up as well. However, I was thinking of doing it myself due to the dealership being over the snowy mountain pass!
https://rennlist.com/forums/showthread.php?t=286509
Thanks![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
The seat is held in by the rail, which is connected to the body by 4 bolts.
Slide the seat all the way back and remove the plastic covers on each rail in the front. They should side off easily by pushing on the tab of the cover. Reveals two bolts.
Losen the two star head bolts, I used a socket but don't remember what size.
Then slide the seat forward all the way and remove the other bolts in the rear.
I just tilted the seat inside the car and followed the cryptic directions on my extinguisher sheet to finish up.
Took about an hour messing around with it.
Which Extiguisher did you go with? By chance is there a link for the "cryptic directions"? Thanks for your help.
Originally Posted by ziege
Just did a fire extinguisher install.
Safecracft with the Brey-Krause Bracket.
Turned out fantastic! The instructions came with the packaging, but they were difficult to understand.
Is this the same as you?
Yeah, after seeing 996Toomey's set up which he provided with pics, looks the way to go. those instructions do look a little confusing!
By chance you have any pics? which colors did you go with?
Thanks ziege for going to the trouble of taking pics. Looks great! BTW, why did you ad the Fire Ext if you don't mind me asking?
Just a nice safety item, never had to use one, though.
Plus it looks good!
