iTunes> MP3 workaround
iTunes music store purchases are protected ACC files that can't be burned as MP3.
The workaround>
Burn an audio CD then reimport as MP3 then make a playlist and burn as MP3 disc.
Presto
The workaround>
Presto
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Originally Posted by djantlive
is there any way to convert mp3 to cd audio so I can play it in my car without ipod?
If you select the audio option it will automatically format the cd to play in cd players...
Straight to Video
I assume this was on all Porsche models but I'd double check.
1 Post
The in dash cd player is capable of playing mp3 disks. The issue is burning an mp3 cd from iTunes, which doesn't seem possible, unless as suggested by MJones that you burn individual audio cd's, and then upload the songs in mp3 format.
To be clear - you can burn MP3 CD's directly from iTunes but just not using the protected songs you buy from the iTunes music store. Unless you employ the work around posted above.
Not in MA anymore
So if I understand correctly, the "right click" option to select "convert to MP3" does NOT work on purchased iTunes songs? No wonder everyone uses Limewire...
Bummer....
Matt
Bummer....
Matt
Don't use Limewire!!! Have a lot of secruity issues w/ it use. Trojan horse, as spy, god what else....Had to offline my daughter's puter because of it. Once it is in your network, it will try to attack the rest of the network...
