Avatar help
Old Jan 8, 2007 | 11:30 PM
OCBen's Avatar
OCBen
There.
MS to the rescue.
Thanks Kurt!
Old Jan 8, 2007 | 11:35 PM
CosmosC4S's Avatar
CosmosC4S
If your Photoshop comes with Adobe ImageReady, use that and save the image under "save for web" or something like that. That will give you a small filesize, yet adequate quality. I had that problem once, reduced the image to the max file size allowed, and the quality dropped so much. Then I discovered that option in ImageReady.
Old Jan 8, 2007 | 11:43 PM
ChipAZ's Avatar
ChipAZ
I never thought of that, although Ben's way works very well.
Old Jan 8, 2007 | 11:46 PM
OCBen's Avatar
OCBen
Chip, your avatar could still be a lot better.
Why not post the pic as an attachment and I'll resize it for you with better resolution, if you like.
Old Jan 9, 2007 | 03:28 PM
ChipAZ's Avatar
ChipAZ
OK Ben I'll take you up on that. I can clean the image up but I still can't figure how to size it using paint. I was trying to make the image size the same as your avatar. Thanks for your help.
File Type: jpg
Old Jan 9, 2007 | 03:50 PM
OCBen's Avatar
OCBen
Try this:
I don't have Photo Editor on my work computer but I tried another program. I'll do another one for you when I get home tonight.
File Type: jpg
Old Jan 9, 2007 | 04:52 PM
ChipAZ's Avatar
ChipAZ
That's 24k and that's the problem I am having. Getting it down the last 5k. Thanks again Ben
Old Jan 9, 2007 | 04:58 PM
kauai_diver's Avatar
kauai_diver
Straight to Video
Yah a little slow at work check this one its compressed quite a bit looks decent but not great:
Irfanview got rid of some of the jaggies and hey its only 13k!
Old Jan 9, 2007 | 05:08 PM
Leader's Avatar
Leader
Here's another "take" on your Avatar. Photoshop "scrubbed" to remove those pesky double-yellow lines and unsightly fence. And straightened the image a bit. It's only 13k, too.
File Type: jpg
Old Jan 9, 2007 | 05:11 PM
ChipAZ's Avatar
ChipAZ
That was too large of a image size and got the dreaded tilt message. That's the problem is get it to be Ben's size, be clear and have it go through. I do appreciate it.
Old Jan 9, 2007 | 05:15 PM
ChipAZ's Avatar
ChipAZ
Leader. That's 200x177. It's got to be at under 180x180 and under 19.5k. Thanks I know there is a way, somehow.
Adding that Ben's is 240x180. How did he that? Maybe it's my computer.
Old Jan 9, 2007 | 05:22 PM
OCBen's Avatar
OCBen
These are the requirements, from Rennlist:
"Note: The maximum size of your custom image is 250 by 300 pixels or 24.4 KB (whichever is smaller)."
Leader, nice job btw.
Old Jan 9, 2007 | 05:32 PM
Leader's Avatar
Leader
You are limited in the size of your Avatar by your "non-member" status. At the risk of stating the obvious, "Members have bigger ones."
Here's one that's under 180 pixels wide and now under 11k.
Old Jan 9, 2007 | 05:34 PM
ChipAZ's Avatar
ChipAZ
Ahhhh, That's it! Guess I better join the club. I've been meaning to do that.
This has been driving me nuts.
Old Jan 9, 2007 | 05:38 PM
OCBen's Avatar
OCBen
Damn good job Leader.
Jump on it Chip. I can't do better than that!
