Break in period
Lets put two engines on a test stand.
Run one at a constant.....say ~ 4000 RPM
Cycle the other continuously from 2000 to 7500 RPM
Which one do you think will last longer ?
While waiting for my C4S to come in I read in AutoWeek that the Porsche break in period is a "CYA" policy by the manufacturer after years of data showed a very high incidence of new 911 driver error under 2000 miles. It is a very precise car. It does exactly what you tell it... and garbage in, garbage out after all.
So, after 16000 + miles in the C2S and a successful PDE master's class, as well as some careful thought about the matter, with the C4S I have driven her like I stole her. She likes it. I like it. Beautiful music.
Personally, I believe that far, far worse than exceeding the RPM limit under 2K miles is "lugging" these flat sixes at low RPM in too high a gear. Do not "lug" the motor... live happy.
Johnny I don't remember seeing that girl in your avatar in the Tequipment catalog!
just my 02....
.As a side note, as somewhat of a science major, we have been taught to never believe what we read without evidence to back up a statement. I have yet to read a scientific explaination as to why the 4200 RPM and 2000 miles were picked as breakin numbers (especially since in 1998, the milage amount was 1000 miles for a similar (but smaller) boxer engine). On the other hand the other camp of 'drive it like you stole it' (provided appropriate warm up) has tried to show engines/pistons/seals/rings broken in this manner to be better than limiting the RPMs during the breakin period. Their evidence seems scientific, and though not double blinded, does make sense (especially the point of the 1st 50-200 miles being the most important/critical period of break-in). That being said, I think that if the engine is appropriately warmed up, taking the car to 5000, 6000 RPM will do no damage (I mean really, what scientific basis is there in limiting RPM's when the engine is warm? Similarly doesn't Porsche red line the engine during the engine oil bath during the factory build?) The best suggestion is to do what you feel most comfortable with. If the aggressive breakin is what you want to do, just follow the suggestions that were in the previos threads.
"Drive it like you stole it" works, but if you do that at 0 miles, you'll wear the engine prematurely, I don't care if the engine is warmed up.
The reason why Porsche may redline their engines before completion is not for the good of the engine. They are trying to immediately identify a problem so as not to put a bad engine out there that will cost them more in the long run. It's a necessary evil. Since their engines run 200,000, 300,000 or more miles, they know they can accept this wear to save money in the long-run. If Porsche had lifetime warranties on their engines, they would not do this.
Five hundred miles used to be the properly break-in time, but with today's synthetics, we need more. I'd vary the engine revs from 1500-4200 during the first 1000 miles, using no more than 50% of the engine power at any given RPM. Change the oil and then start running the engine pretty good after that (80% for 500 miles). The remaining 500 miles and 100% can and should be used to run the engine "like you stole it." At this point, you'll be stressing the remaining components of the car, such as bushings, body panels, seats, etc.
I should also mention that a 3,000 mile trip is only good if you make sure you cold/hot cycle the car enough times to complete the break-in process. Running the car non-stop does not give the car a change to expand/contract for break-in.
Are you saying that you would reccommend changing the oil at the 1000 mile mark?
DAAAAAMMMMMMMMN! She is spectacular!
-don
There is one major problem associated with keeping break-in oil in the engine for too long:
Engines are assembled with lots of different grease and oil compounds. For example, there is usually special camshaft lube that is not like motor oil and is required for break-in of the camshaft lobes. There is usually heavy grease applied to some needle bearings, during assembly. I've seen valve springs coated with a sticky oil substance that is clearly not engine oil. And then you have some parts that are actually painted or have some paint overspray due to manufacturing. Also keep in mind that many of these parts are exposed to airborne particles during assembly, such as dust. Some of these parts simply have a very thin layer of soap residue leftover from cleaning. So all these components are going to mix together when the engine breaks in.
How do you get all this stuff out of the engine? Changing the oil is the only way. Yes, synthetic is almost that good, but it is not good enough to actually clean the oil and remove dirt.
The other problem is rare, but I have seen it, and it has to do with the oil filter. When an engine breaks-in, you get a lot of metal shavings and metal debris that comes off into the oil. The oil filter catches most of the bigger pieces, while the drain plug magnets catches the rest. Some stays in the oil in liquid form and bypasses the filter, causing no real damage. A problem can occur, however, wherein the large pieces of sharp metal, under pressure from the pump, can puncture a hold in the filter and let some of the pieces out into the oil system. This can lead to a reduced lifespan or possibly serious engine damage for obvious reasons. A good filter, like the ones on a P-car, should not have this problem, but it can happen. I would change the filter after break-in for this purpose, along with the oil of course.
So, if you don’t want to change the oil at 1,000 miles, I would for sure change the oil and filter at 2,000 miles. After that, 7,500 miles seems to be an accepted oil change interval for most engines running synthetic.
Cars these days are built in pods in different parts of the factory or maybe even at a sub-contractors. Transmissions in one pod. Engine in another. Suspension in another, etc etc etc.
When moving parts that are manufactured away from each other are finally assembled together , it is important that they mate up properly and this is primarily why all manufacturers stress a break in period.
Your doing more damage to a motor lugging at 2-3000rpm. You have to run it throughout its entire rpm range, once it is fully warmed up.
