Rector Porsche
Originally Posted by Vancouver83LTD
Because Americans are notoriously sue happy
And yet another glittering generality. You still have some time on how to learn to win friends and influence people. Get with the program!
Newbies Hospitality Director
Just got an email from them. Not sure if this is expensive or not but for those who is interested:
Due to overwhelming popularity during the Spring, Porsche of Stevens Creek is offering an End of Summer Oil & Filter Special. It includes an Oil & Filter Replacement and 14 Point Visual Inspection of most of your vehicles vital systems, all for only $199.00 plus tax. Plus we are also offering 10% off regular scheduled maintenance. Please feel free to stop by and see our new service facility with 9 Certified Porsche Trained Technicians.
mention the End of Summer Oil & Filter Special.
End of Summer Service Coupon
10% off Regular Scheduled Maintenance
$199 Oil & Filter Replacement
14 point visual inspection includes:
Underside of vehicle & engine compartment: Visual inspection for leaks (oils & fluids) & chafing (wires, lines & hoses) Check that the underbody paneling is securely fastened-replace any damaged and/or missing panels Radiators and air inlets: Visual inspection for external debris and blockage Power-assisted steering: Check fluid level Brake hoses and lines: Visual inspection for signs of damage, correct routing and corrosion Brake fluid: Check level Steering gear: Visual inspection of the bellows of damage Tie rod ends: Check play and dust boots Axle joints: Check play, visual inspection of the dust boots for signs of damage Drive shafts: Visual inspection of the boots for leaks and signs of damage Tires and spare wheel: Check condition and tire pressure Vehicle lights: Check operation. All headlights: Check alignment Horn: Check operation All other electrical equipment as well as indicator and warning lights: Check operation
update on stevens creek service:
1st they changed the oil
2nd Vibration at 80 was caused by my left rear tire totally separated on the left inner sidewall
you could stick your hand up into the tire! this is a dangerous situation and the tire didnt even show flat.
...anyhow they are keeping my car over the weekend until they can get new tires on monday.
3rd. got a caddilac loaner for the weekend for free.
..so far so good and no complaints yet. i'll make sure to take in the 10% off ad posted on thier web site.
anybody else have any issues with tire failures, but not seeing it right away?
