Quick question on Langka (chip repair)
Anyone used it on their 997? Any risk to damaging the surronding paint around the chip(fine scratches, swirls, paint removal, etc.), or is it pretty safe.
I got my first chip today.
I used it a while ago. Not impressed. I ended up using a pin head to apply 1 or 2 coats to where it just bumps up above the rest of the paint then wet sanded it every so lightly ( sandpaper sized to eraser tip size) and slowly after 2hrs drying time. Why 2 hrs? Did not want the paint to cure so it could be sanded easily and 'spread' a tiny bit.
On silver the chips are impossible to see unless I point them out to ya.
I got my first chip today.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
But you might want to be careful if you're repairing a chip on a freshly resprayed panel (I think Langka even says something to that effect on their website).
Just wanted to give an update.
I applied two drops of touch up paint this morning to the tiny chips. Waited 7 hours. Wrapped a credit card in a piece of cotton pillow case (just like they suggest for Langka use) and dabbed the pillow case with a couple drops of Rubbing Alcohol. Gently ran the card back and forth over the touchup bumps and it smoothed them down perfectly. I then wiped the area with a wet cloth, and then lightly buffed it with a microfiber cloth.
Looks great.
Chad
Looks great.
Chad
I bought and used this product with mixed results. It DOES remove the excess paint, but I found it frequently pulled ALL the paint right out of the chip (and you're back to square one). Also, metallic touchup paints are generally a mediocre match. Touchups generally work out better on solid colors.
Originally Posted by WCE
So the rubbing alcohol dissolved the excess paint just like Langka?
I let the touchup paint dry for only 7-8 hours before I used the alcohol. Took maybe a minute of light rubbing, that's about it. I also felt more comfortable using a couple drops of alcohol on the paint.
