"If you purchase a car with the PCM, under the main display, if you push the set button, you have the option of activating or de-activating the day time driving lights. So if your car has PCM, ie the navigation system, it already is equipped with daytime driving lights. Even from the US."
If no PCM/Sport Chrono, you can have the dealer do it with PIWIS, I think. At most, you'll need a new relay (also gleaned from previous a previous post...).
I believe you must have the sports chrono package (not 100% sure on that).
I programed mine a couple of weeks ago. It's in the PCM manual (page 23? if i recall correctly)
You have your "main" screen up and hit the "set" button on the right. That brings up some choices one of which is lights/daytime driving
Thanks for your input. I have the PCM with NAV, but do not have the Sport Chrono or the multi-function steering wheel. Under MAIN, SET -- my screen displays only PCM SYSTEM and MAIN DISPLAY (list does not include INDIVID. MEMORY and STEERING WHEEL) and I can not get to a sub-menu for INDI*******MORY, which is, apparently, the sub-menu which includes LIGHT, WIPER, etc.
So... I'll try the dealer if they can set daylight running lights under PIWIS.
