Tinted Front Windows
Old Mar 9, 2006 | 07:34 PM
woodranch's Avatar
woodranch
Default Tinted Front Windows
For those of you fellow California forum members what is the current law for front window tinting.Is it not allowed at all or can you tint them lightly?Thanks
Old Mar 9, 2006 | 08:07 PM
THPorsche's Avatar
THPorsche
By law, you cannot tint the front windows unless there is a medical reason but I hardly hear anyone gets ticket for that unless it's a very very dark/ mirrored tint.
Old Mar 9, 2006 | 08:11 PM
Leader's Avatar
Leader
If you get stopped for any other reason, the officer will probably write you up for tinted front windows along with whatever other citation you're getting. The "tint violation" is a "fix it" ticket, meaning you will have to strip off the tint, take your car to a CHP station and get an inspector to "sign off" that the tint has been removed. The whole process can be a royal pain, but if you gotta have tint, just keep it the lightest shade and hope you don't get pulled over for ANY reason.
MJones's Avatar
MJones
Material Obstructing or Reducing Driver's View
26708. (a) (1) No person shall drive any motor vehicle with any object or material placed, displayed, installed, affixed, or applied upon the windshield or side or rear windows.
(2) No person shall drive any motor vehicle with any object or material placed, displayed, installed, affixed, or applied in or upon the vehicle which obstructs or reduces the driver's clear view through the windshield or side windows.
(3) This subdivision applies to a person driving a motor vehicle with the driver's clear vision through the windshield, or side or rear windows, obstructed by snow or ice.
(b) This section does not apply to any of the following:
(1) Rearview mirrors.
(2) Adjustable nontransparent sunvisors which are mounted forward of the side windows and are not attached to the glass.
(3) Signs, stickers, or other materials which are displayed in a 7-inch square in the lower corner of the windshield farthest removed from the driver, signs, stickers, or other materials which are displayed in a 7-inch square in the lower corner of the rear window farthest removed from the driver, or signs, stickers, or other materials which are displayed in a 5-inch square in the lower corner of the windshield nearest the driver.
(4) Side windows which are to the rear of the driver.
(5) Direction, destination, or termini signs upon a passenger common carrier motor vehicle or a schoolbus, if those signs do not interfere with the driver's clear view of approaching traffic.
(6) Rear window wiper motor.
(7) Rear trunk lid handle or hinges.
(8) The rear window or windows, when the motor vehicle is equipped with outside mirrors on both the left- and right-hand sides of the vehicle that are so located as to reflect to the driver a view of the highway through each mirror for a distance of at least 200 feet to the rear of the vehicle.
(9) A clear, transparent lens affixed to the side window opposite the driver on a vehicle greater than 80 inches in width and which occupies an area not exceeding 50 square inches of the lowest corner toward the rear of that window and which provides the driver with a wide-angle view through the lens.
(10) Sun screening devices meeting the requirements of Section 26708.2 installed on the side windows on either side of the vehicle's front seat, if the driver or a passenger in the front seat has in his or her possession a letter or other document signed by a licensed physician and surgeon certifying that the person must be shaded from the sun due to a medical condition, or has in his or her possession a letter or other document signed by a licensed optometrist certifying that the person must be shaded from the sun due to a visual condition. The devices authorized by this paragraph shall not be used during darkness.
(11) An electronic communication device affixed to the center uppermost portion of the interior of a windshield within an area that is not greater than 5 inches square, if the device provides either of the following:
(A) The capability for enforcement facilities of the Department of the California Highway Patrol to communicate with a vehicle equipped with the device.
(B) The capability for electronic toll and traffic management on public or private roads or facilities.
(c) Notwithstanding subdivision (a), transparent material may be installed, affixed, or applied to the topmost portion of the windshield if the following conditions apply:
(1) The bottom edge of the material is at least 29 inches above the undepressed driver's seat when measured from a point 5 inches in front of the bottom of the backrest with the driver's seat in its rearmost and lowermost position with the vehicle on a level surface.
(2) The material is not red or amber in color.
(3) There is no opaque lettering on the material and any other lettering does not affect primary colors or distort vision through the windshield.
(4) The material does not reflect sunlight or headlight glare into the eyes of occupants of oncoming or following vehicles to any greater extent than the windshield without the material.
(d) Notwithstanding subdivision (a), clear, colorless, and transparent material may be installed, affixed, or applied to the front side windows, located to the immediate left and right of the front seat if the following conditions are met:
(1) The material has a minimum visible light transmittance of 88 percent.
(2) The window glazing with the material applied meets all requirements of Federal Motor Vehicle Safety Standard No. 205 (49 C.F.R. 571.205), including the specified minimum light transmittance of 70 percent and the abrasion resistance of AS-14 glazing, as specified in that federal standard.
(3) The material is designed and manufactured to enhance the ability of the existing window glass to block the sun's harmful ultraviolet A rays.
(4) The driver has in his or her possession, or within the vehicle, a certificate signed by the installing company certifying that the windows with the material installed meet the requirements of this subdivision and identifies the installing company and the material's manufacturer by full name and street address, or, if the material was installed by the vehicle owner, a certificate signed by the material's manufacturer certifying that the windows with the material installed according to manufacturer's instructions meets the requirements of this subdivision and identifies the material's manufacturer by full name and street address.
(5) If the material described in this subdivision tears or bubbles, or is otherwise worn to prohibit clear vision, it shall be removed or replaced.
Old Mar 9, 2006 | 08:16 PM
woodranch's Avatar
woodranch
M.Jones is that a yes or no?
Old Mar 9, 2006 | 08:59 PM
Zto997's Avatar
Zto997
Cruisin'
No tint allowed on front windows at all. I usually just roll down my windows whenever I see a cop cruising slowly by. One thing to remember: the same tint will appear much darker with a black interior than with a lighter one.
Old Mar 10, 2006 | 12:07 AM
OCBen's Avatar
OCBen
Hey Woodranch, you having problems with short term memory? ... You started an identical thread in December and it's hilarious you can't remember a thing from it. A simple search using the keyword 'tint' turned up your very thread:
https://rennlist.com/forums/showthre...highlight=tint
And this post where I answered the very question you're asking now:
https://rennlist.com/forums/showpost...2&postcount=26
Old Mar 10, 2006 | 12:03 PM
woodranch's Avatar
woodranch
Hey Ben do you know how to read?Those 2 posts ask compmletely different questions.First question has to do with the look of the car if you tint the windows.2nd question has to do with the legal issues of tinting the front windows.Now go take your medication and relax and get off my back.Are you the President of this forum that just rags on people that asks questions even if it was repeated before.You are a little aggresive,no?
Old Mar 10, 2006 | 12:57 PM
OCBen's Avatar
OCBen
Default Illegal in California
From your 1st post here:
And in that referenced thread:
Originally Posted by OCBen
Only the side rear windows can be tinted. Windshield, side windows, and rear window shall not be tinted according to the law:
"Transparent Materials
26708.5. (a) No person shall place, install, affix, or apply any transparent material upon the windshield, or side or rear windows, of any motor vehicle if the material alters the color or reduces the light transmittance of the windshield or side or rear windows, except as provided in subdivision (b), (c), or (d) of Section 26708.
(b) Tinted safety glass may be installed in a vehicle if (1) the glass complies with motor vehicle safety standards of the United States Department of Transportation for safety glazing materials, and (2) the glass is installed in a location permitted by those standards for the particular type of glass used."
CA DMV VEHICLE CODE, SECTION 26708
http://www.dmv.ca.gov/pubs/vctop/d12/vc26708.htm
I suggest you learn how to use the search feature here. It comes in quite handy as you can see.
Old Mar 10, 2006 | 04:03 PM
SrfCity's Avatar
SrfCity
Tinting is asking for an excuse to get pulled over and possible ticket IMO.
Old Mar 10, 2006 | 04:07 PM
OCBen's Avatar
OCBen
Your problem is that you think this forum is your personal source of free information. That anytime you feel like asking a question, even though you may have asked it before, you feel you have the right to expect us to be at your constant beck and call, and jump on it as your servants and dig up the very information you could have found yourself.
It should come as no surprise that a simple search of threads started by you reveals a pattern of multiple threads asking for basically the same information, often closely spaced together in time. I really don't know what kind of problem that's an indication of, but when I saw that you had made MJones dig up the very information I had provided to you earlier (as if he didn't have anything better to do with his time) and then you had the audacity to ask him if that was a yes or a no, as if you were too lazy to read the quote for yourself and wanted him to provide a summary and a conclusion for you? Well, that just came across as a bit pathological, don't you think?
Get one thing straight, okay? You are not paying for this service, so don't act like you're entitled to anything and everything you ask for. And even if you were a paying Rennlist Member, that wouldn't entitle you to take advantage of us, and ask us to dig up something you could easily do yourself, especially when the information is in a recent thread started by you. And don't be surprised if the next time you start a thread asking for information that you get a tepid response, if at all. ... We are not your servants.
Old Mar 10, 2006 | 04:24 PM
robbonds's Avatar
robbonds
damn
Old Mar 10, 2006 | 06:49 PM
Leader's Avatar
Leader
Recommended reading: Internet Writing Guide & Flame Wars & Other Online Arguments.
Old Mar 11, 2006 | 12:59 PM
woodranch's Avatar
woodranch
Oc do the words suck me mean anything?
Old Mar 11, 2006 | 01:01 PM
Leader's Avatar
Leader
I see "Mr. Ranch" has opted to skip the recommended reading.
