997S US vs Euro Spec?
Hello, I'd like to understand if there's any difference in suspension settings between both versions? I know that in the past the us versions was a little higher and softer, right? Is it true that now ROW and US versions have the same suspension?
Thanks in advance!
Thanks in advance!
There is a difference between US and ROW as shown on the attached Adjustment values for suspension alignment as of MY 2005 sheet shown below.
Also the parts list US vs ROW has different spring #'s and color codes.
But now I'm all confused...on my car the spring color code comes up as ROW not US
Those with an "S" coupe look thru your rear wheel at the spring and tell me what color code your springs are very easy to spot (mine are Red/White)
Seems that the more info you have the less that you know
