First oil change.
Originally Posted by OCBen
Sounds like you may not have changed the oil filter on a P-car before. They're not the one piece units like Fram that you screw in by hand. On a P-car the filter is actually an internal insert made of paper-like/cardboard material that you simply throw away and replace. The external cannister, which is threaded at the top, is the piece that is removed with that special socket Johnny speaks of. It's really simple to do, but you need that special socket to make the job easy.
I don't understand the statement of OCBen above. Where are these paper filters located? Are they in the threaded cannister you can just take off? Where do you find the Porsche filters to replace the old ones? And, no.... I have no idea about doing my first Pcar oil change.....but it sounds so easy, why not? Mobile 1 0-40 is only $7.50/quart here. And the only other thing I would need is the paper filter? Im at 4000 miles now, and I don't like the idea of breaking a car in and then driving it on the same oil for 20k.
get the paper filter from ebay or any online porsche dealer (usually cheaper than your local dealer).
get the mobil 1 from autozone or any equivalent store...
I stocked up on supplies when i first got my car
I got 6 oem porsche filters with all the rings etc for about $60
and 4 cases of mobil 0-40 for 4.50/quart, I think the regular price is like 5.99 but they usually discount them.
Just had my 997S in for it's 20K service at MY Porsche in Monterey. Actually the car told me it was ready at 18,500 miles. I took 9 qts of oil with me (paid $5.59 qt at Kragen) This saved me about $50 so I guess the dealer was going to charge me $12 qt. Total for the 20K service was $304 with tax, plus the $54 I paid for the oil.
While it was there they also did 3 recall repairs and fixed an issue that I had with the passenger seat cushion. Took about 4 hours and they gave me a free rental car to use (I couldn't talk them into loaning me the new Cayman)
The first oil change was done at 8500 miles. I really don't see the point in changing the oil any more frequently than that, especially if you have a dealer do it. I would change oil once a year though, no matter who few miles I put on the car.
I changed mine at 2500 miles after breakin period. Dealer did it without any objections. My question is for us owners who live in the NorthEast and have to let our cars sit for awhile, should we change the oil again in the spring before beginning another season? Does something happen to the oil after letting it sit idle for a long period of time?
Jay
Jay
Jay
Jay
From Renntech.org: http://www.renntech.org/forums/index.php?showtopic=7055
That DOES look easy. Boy, you guys sure are getting a deal on the Mobil 1.
0-40 costs me $7.50/quart.
Originally Posted by Larry Harris
My 06 has 1800 miles on it. I plan on having the dealer change the oil at 2000 miles. Some of you may feel this is premature and perhaps a waste of money.
I have always been a believer in 3000 mile oil changes and have never lost an engine. I know this subject has been discussed many times before and have read almost everything ever posted. The car has used 1 quart of Mobil 1 in the 1800 miles. The car runs perfect and I want to keep it that way. After the initial change I will do subsequent changes twice a year, June and December.
In the end it all depends upon what you are comfortable doing ... personally I would make sure the air filter is clean (change it often) and do the changes at 10K.
Originally Posted by uzj100
Just the way I learned... --and of course I learned the hard way about too tight filters and drain plugs, and loosening and draining differential and transfer cases, then discovering that the fill plugs are frozen on
Even though I've done it a zillion times I always use a reliable torque wrench. That way you'll never run the risk of overtightening.
On some torque wrenches actual vs.spec torque can be off by +/- 4% or more. Hmmmm, I know you're an engineer so maybe you've got acess to a torque calibration machine at your work, or know someone who does.
These discussions are always good to share little "secrets" or tricks learned over the years--and as I said I've had to learn them the hard way many times
Thanks fast 1. I will not change oil in the spring. As a matter of fact I was able to get my car out on the morning of Christmas eve, let it warm up and went on a 40 minute run. She ran with precision. A little white smoke when warming up, but that dissapated as the enging reached temperature.
Thanks for the info.
Jay
Jay
Miserable Old Bastard
I changed mine at 10 months / not quite 10,000 miles. My mechanic (who I trust) told me not to waste money doing it earlier. Dealer charged $161 for labor, oil and filter.
Johnny Narcosis ,
You do not have to spend $25 or more for the oil filter wrench .
You need a 74 mm wrench which can be purchased at most car part stores for under $5.
I bought one at Walmart for $ 2.95
PS: The same wrench also fits my MB.
