Oil consumption
Old 08-31-2006, 05:34 PM
  #61
Edgy01
Poseur
Edgy01's Avatar
Originally Posted by Edgy01
How many 997 engines have you been into? How many 996 engines?
Why should anyone listen to you over Porsche?
What is your engineering degree in?
Are you a Porsche mechanic? Assuming 35 years as one,--right?
(I'll appreciate your inputs a lot more if you just enlighten me!)
I directed this to 1999Porsche911 several days ago. Still, no reply citing his background in this field.
Old 08-31-2006, 05:57 PM
  #62
1999Porsche911
1999Porsche911's Avatar
Originally Posted by bgiere
I agree that people should make educated decsions. So please provide us the information to support and define your position. I still have yet to see any proof provided by you, other than conjecture, that supports your statements. You refuse all factual data, all experts opinions, and continu to mis-inform people who come to these forums looking for help and advice. I think i have to use the ignore button now....
Any recommendation I may have given regarding using a 15w50 wt. M1 oil was not for a 996/997 engine. And I will restate to you that 15w50 M1 was not and is not available as a factory fill for the 996. What I stated was that it MAY have been M1 5w50.
But how cann ANY Porche from 1984 on survive with 15W50? It is not approved by Porsche. What is different about a 1986 911 and the 996 that requires 15W50? Remember. Porsche does not approve of that. What is your detailed and proven reasons why YOU say it is OK?
Old 08-31-2006, 06:19 PM
  #63
1999Porsche911
Additionally. Porsche documentation expressly warned against using any viscosity of oil less than 10W40 in any climate where average temperatures are above freezing in the early 996's.
Old 11-24-2006, 01:45 PM
  #64
snarf
snarf's Avatar
I thought I would resuscitate an old thread and see if there is now a consensus on what's considered good, normal and excessive for these engines.
Since changing my oil (C2S, Mobil 1 0W-40) at 1900 miles I've done a little under a 1000 miles and added 0.3 litres of oil (1 litre is approximately 1 US quart) but not sure how much of this is catch-up as a result of being overly conservative during the oil change with the level as I didn't want to overfill. At worst this would be around 3000miles/litre so not too bad - I think I would classify this as normal for this engine but years of driving cars that rarely required any oil between changes still leaves me feeling a little dissatisfied.
Old 11-24-2006, 02:06 PM
  #65
ChipAZ
ChipAZ's Avatar
I've put in a half a quart in 6000 miles. A lot of those miles have been long trips on the interstate. I do red line it every time I drive it to keep the Tip tranny trained and I drive it hard on mountain roads. The gauge always shows full.
Old 11-24-2006, 02:38 PM
  #66
Ian C
Ian C's Avatar
Snarf - I'm getting around 4000 miles per litre with my C2S but this is more than any other Porsche I've had in the past. Seem to remember very rarely putting anything in between services
Old 11-25-2006, 02:04 PM
  #67
UK997C2S
UK997C2S's Avatar
Snarf and IanC, I've just added 0.2 litre 1000miles after oil change at 6000miles (so 5000 miles per litre, C2S manual). Oil consumption seems to have decreased (improved!) since the oil change, but it may simply be due to bedding-in. I aim to have the oil level indicator one bar lower than 'full' when the engine is cold and on the level, but I find it's worth checking this 2 or 3 days in a row to be sure of the real level. It then usually shows 'full' when the engine is hot.
Old 11-25-2006, 04:32 PM
  #68
snarf
snarf's Avatar
Originally Posted by UK997C2S
. . . I aim to have the oil level indicator one bar lower than 'full' when the engine is cold and on the level, but I find it's worth checking this 2 or 3 days in a row to be sure of the real level. It then usually shows 'full' when the engine is hot.
Interesting point, I tend to check mine when cold. After filling the tank I am usually too embarrassed to wait the necessary 3 to 5 minutes when there are others queuing for the pump. Why do you think the level goes up when hot - expansion? Before reading your post I would have expected the hot level to be a little lower because of the oil remaining in the system.
Old 11-25-2006, 06:34 PM
  #69
MichaelL
MichaelL's Avatar
My oil consumption is holding at around 1 pint per thousand miles. The car has 15,500 miles(in 15 months) and was broken in in general conformance with the manual. Th engine has been regularly run into high rpm's and allowed to coast down in gear. The car has been driven vigorously, but carefully. It is used as a daily driver, with frequent short trips around town and heavy traffic highway. Used 2 quarts in the 2000 mile break-in and leveled out at half that consumption.
Old 11-25-2006, 06:38 PM
  #70
MichaelL
MichaelL's Avatar
Have used 0W40, as recommended, but may switch to 10W50 on the next oil change. Under superhot conditions, the oil pressure stays just under 1.5 bars.
Old 11-25-2006, 06:48 PM
  #71
UK997C2S
UK997C2S's Avatar
I assume it is expansion, and perhaps cold oil has a chance overnight to settle into all the nooks and crevices of the engine. I expect someone brighter than me will answer this more intelligently! I'm pretty sure my oil consumption is gradually decreasing, while the engine seems to be smoother and more responsive.
Old 11-25-2006, 08:37 PM
  #72
mdrums
mdrums's Avatar
I have 4500 miles on my C2S. I have done a lot of spirited driving and a DE at Sebring. So far I am just 1 line down....no need to add oil yet. Car runs strong too.
Old 11-25-2006, 09:55 PM
  #73
4thporsche
4thporsche's Avatar
My oil consumption has mitigated now that the car has more miles. 2 quarts first 2000 miles, 1 bar down the last 1800. Lots of stop and go traffic in LA.
Old 11-25-2006, 10:24 PM
  #74
gpjli2
gpjli2's Avatar
"...oil pressure stays just under 1.5 bars." I assume you are talking about reading at idle. I was noticing today that my oil pressure runs about 2+ bars per 1000 rpm. I am at 5 bars by 2500-3000 rpm on the road. This is higher than manual specifies (5000 rpm= 3.5 bars) but seems to be what others have reported on this forum. You might try Mobil 1 5-40 for a somewhat more viscous oil, especially in the summer months. Gerry
Old 11-26-2006, 01:43 AM
  #75
drmatara
drmatara's Avatar
Used 2qt in 9000 miles on my C2S cab. First qt after 2k and an other one 2k later...since then...no consumption at all
Quick Reply: Oil consumption
