adhesive removal advice please
i have some residual tape adhesive on my wheels that seems to not want to come off. what can i use to remove it? rubbing alcohol? thanks
That citrus, orange stuff really works and doesn't harm any finish.
Use solvents in this order:
alcohol, liquid parafin
kerosene (lighter fluid), Goo Gone
Toulene, acetone, MEK (Goof-off, nail polish remover)
Alcohol may be slow but safest.
Acetone (and the others in it's class) is quick but very aggresive. Can cause immediate and/or unseen but cumulative damage
Originally Posted by Itzkirb
I second Goo Gone from Home Depot.
DO NOT confuse it with "Goof Off" which is a cocktail every retail aggressive solvent in the book. (toulene, acetone, MEK...?). Also very good stuff but be very careful using on your car (it "melts" plastic).
you may want to get yourself some of the 3M general adhesive remover or i suppose you could continue to use the wd40... just i would highly advise you to (after you use the "remover") quickly flush the area with some soapy water then rinse.
Don't use Acetone unless you really want it to strip paint and clear coat, melt plastic, or eat your skin.
