Checking oil level.
Old May 3, 2005 | 11:32 AM
PDQ PDK CAYMAN S's Avatar
PDQ PDK CAYMAN S
Default Checking oil level.
Does your display check oil every time you fill up? Mine had done it twice in 6,000 miles.
Old May 3, 2005 | 11:36 AM
Gary R.'s Avatar
Gary R.
Have not seen a "Check Oil" display at all yet, about 4500 miles.
Old May 3, 2005 | 11:41 AM
CO997's Avatar
CO997
I've not seen that either. I do check the bar graph that comes up every time you turn the key to check the oil level, is that what you are talking about?
Old May 3, 2005 | 12:13 PM
MJones's Avatar
MJones
1. Ignition is switched off.
2. If the engine is at operating temperature, at least 5 minutes must elapse between parking
the vehicle and starting the engine.
3. Refuelling completed within 15 minutes.
When the ignition is switched on, the engine oil level is shown on the segment display.
Yes it does work if the above preconditions are met, upon restarting the oil level is displayed and remains for a bit... take some time and hang out next time you re-fuel
Old May 3, 2005 | 05:50 PM
PDQ PDK CAYMAN S
Thanks, I did have a problem at the pump and had to go inside and that is why I saw the oil level last time I added fuel.
Old May 5, 2005 | 11:54 AM
Buzz911S's Avatar
Buzz911S
I have an 05 911S and I always check the oil display bar before I start the car. It gives you a true reading immediately and you don't have to sit there and wait the 5 minutes it takes to check it when the engine is at operating temp.
Here's an issue I've had that i don't understand yet. My car has only 500 miles on it, and the other day at a traffic light I stalled the car. I hit the starter and nothing happened. The people behind me were getting a bit pissed....so I turned the key all the way to the left and then back to the right and it started. What's up with that?
Old May 5, 2005 | 01:21 PM
DD694's Avatar
DD694
That is how it is done. I am sure it has to do with the electronics. Must follow same start-up sequence.
Old May 5, 2005 | 04:22 PM
PV's Avatar
PV
Isn't that the case with every car these days, that you need to turn the key all the way back? You basically reset all the settings for start-up.
Old May 5, 2005 | 05:07 PM
OCBen's Avatar
OCBen
Isn't this so that you don't grind the starter pinion gear against the flywheel in the event the engine is still running but you think it quit and are trying to restart it?
Old May 6, 2005 | 11:34 AM
Buzz911S's Avatar
Buzz911S
No, not in any car I've owned before. In this instance, the starter would not engage until I turned the key all the way to the left first. It is normally in a "neutral" position after starting. I had to turn it from it's "neutral" position to the left....back to the middle and then to the right before it would start.
Old May 6, 2005 | 12:03 PM
boolala's Avatar
boolala
That's normal.
Old May 6, 2005 | 12:09 PM
SrfCity's Avatar
SrfCity
It is a little embarrassing because it seems to take for ever to do...... They do seem to stall on occasion if you load it up a little to early.
Old May 7, 2005 | 12:25 AM
gr8330's Avatar
gr8330
BMW is the same
