Okay, anyone using the GSM phone???
Hi all,
Thanks in advance for any help. I just purchased a GSM phone from Cingular. I removed the SIM card from the phone and inserted it into the drawer. The phone turns on and then says "initializing phone" then it remains stuck on "checking card". I AM ABLE to dial "9-1-1" using the "emergency call" option, but I can't get it to go past "checking card" Is it because Cingular didn't put a PIN on the card, and the PCM module is looking for one? The phone must be working since I can dial 911...ANy thoughts???
Miserable Old Bastard
I think all / most cell phones can call 911 without a SIM card or being activated. Will be interested to see how your install works out.
Originally Posted by jcnesq
I think all / most cell phones can call 911 without a SIM card or being activated...
Originally Posted by JTW
You need to install the SIM card.
Any thoughts?
My bad...the emergency function does work without a SIM card. I am getting a bit worried that the SIM card drawer is defective...
Sorry, I did misunderstand. Try this forum for all information cell phone related:
http://www.howardforums.com/
There are two types of SIM cards used in GSM phones with different voltage. The newer standard is 3 Volts and the older one is 5 Volts and there can be problems using 5 volt cards in newer phones.
Originally Posted by BD997
what are we doing...I also have a sim/cingular...what are we attempting to do...?? Sorry if I missed previous threads....
There is a separate add-on option called the "Porsche Cellular Solution" I think. I don't think it is the same thing as the integrated module in PCM installed at the factory, but I could be mistaken. I would wait to see if I can get this thing working with a Cingular SIM before plunking money down on a new PCM. Otherwise it'll be a $960 9-1-1 dialer...just great
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
really???it it available as an add on after....?
This running production change occured in Nov '04 The new faceplate is now the worldwide standard and will come on all 997 and 987 models that have PCM.
If you have the early faceplate with-out SOS button and SIM card slot, looks like you will NOT be able to retrofit.
