IPOD
I'm using the iCarPlay in both the Cayenne and the Carrera S. Because it is powered off the cars 12v system the transmission is 100% stronger than the battery powered POS that I smashed with a hammer in frustration... though even the iCarPlay is not as good as a direct AUX plug in or an FM Modulator input box. This iCar stores 3 stations on push buttons that makes moving to a stronger station easier. I just match them with the first 3 stations on the radio button memory. Though it is still not flawless.
If it were easier to get behind the radio to the antenna plug I'd install an FM modulator on the antenna line. That is a flawless sound option and available at Crutchfield, et al.
Unfortunately, the Ice link will not support the newer Porsche radio at this time. We are working on a kit for your application in the meantime.
If you would like to be placed on our waiting list, we will need the following information from you:
First/Last Name:
Year:
Make:
Model:
iPod Generation:
Daytime Phone Number:
Email address:
If you have any further questions, please feel free to contact me directly.
_________________________________________________
Tom Guagliardo | Cust. Support, Dension USA
direct: tom@densionusa.com
support: support@densionusa.com
web: www.densionusa.com
tel 866.822.3673 x115
sales 562.595.5153
fax 562.864.4010
"Let the Music be with You!"
This E-Mail/telefax message and any documents accompanying this transmission may contain privileged and/or confidential information and is intended solely for the addressee(s) named above. If you are not the intended addressee/recipient, you are hereby notified that any use of, disclosure, copying, distribution, or reliance on the contents of this E-Mail/telefax information is strictly prohibited and may result in legal action against you. Please reply to the sender advising of the error in transmission and immediately delete/destroy the message and any accompanying documents. Thank you.
On Fri, 10 Dec 2004 18:22:19 -0700, xxxxx wrote:
> This is an enquiry e-mail from Tony Holm
> When will you have an iceLink for PORSCHE with fiber optic radio
> system (PCM II) available for my 2005 911/997?
http://www.monstercable.com/
Switch your sterio to CD changer mode and the ipod should come through with much better quality than any FM modulator. The downside is you loose your CD changer but who needs one when you have 1000s of songs on the ipod?
I will take a look at my 996 tomorrow and see if I can find the part that works for it and post it here.
