DME Report -- Walk away?
Like others have said it appears as a single "Money shift", but the car was driven quite spiritedly.
If you have plans in the future to rebuild regardless and can save a chunk of cash upfront, I would do it.
BTW - Where are the Bore Scope Inspection photos? Import part opf the PPI on these cars.
I appreciate everyone's input. I think the car currently priced a little high based on what you guys are saying, so I'm going to negotiate with the seller. If they come down on the price, I'll probably take it, otherwise I'll pass.
This thread isn't about bore scoring and there are plenty of other threads on it. But bore scoring is real and an invasive inspection should be part of any PPI for a car you want to be absolutely sure about. If you want to pass on that and take the risk at least get an oil analysis which is cheap and easy and would let you know if you could have an issue. Good luck with the purchase....
To suggest listening to the engine and hearing no ticks or noises isn't how to check for Bore Scoring.
2 997's I PPI's/Bore Scoped and had scoring ran fine with no smoke on startup, no noises, no soot on tailpipes because they had most likely been cleaned.
A $250-$300 Bore Scope thru spark plug holes IMO is a smart preventative measure.
Its an iconic car regardless of age or generation, some generations are more sought after and some are not as popular.
I prefer cars that age well with you, the 911 certainly fits that bill.
Its why I am in general, a bit forgiving with these cars, especially with a buyer who is going into it with both eyes open.
Here's a quick down and dirty most certainly incomplete list:
356 - Poor cooling resulting in engine in most cases(Pardon Pun) needing rebuild within 75-85K miles. Aluminum oil cooler suggested
Early 911's - Had fuel injection issues
75-77 911S - Broken headstuds, poor transmission sycros resulting in top end engine rebuild and transmission rebuild
78-1983 911SC - Broken headstuds, poor transmission syncros, poor chain tensioners resulting in top end engine rebuild and transmission rebuild
84-86 911 Carrera - Poor valve guides requiring head rebuild
1989-1992 964 - Major oil leaks due to no case seal - Top end engine rebuild required and most always complete engine rebuild
1995-1998 993 - Engine head air passages become clogged, therefore not passing emissions on post 1995 OB11 and require top end engine rebuilt - 1995's run like crap when heads are clogged but will pass emissions
1999-2003 996 - IMS issues requiring IMS replacement
2005 997 - IMS failures requiring engine rebuild or replace IMS Bearing prior to failure
2005-2008 997 - Low % of Bore Scoring requiring engine rebuild - Auto transmission problems requiring sensor replacement or rebuild.
2009-2012 997 small % of Bore Scoring " ' " " - Auto Transmission problems " " " " "
Now if you have for instance a 993 with top-end engine issue, you have it fixed in most scenarios and keep the car.
The 997 is currently in this cycle. The 997.1 generation has officially made its way into the classic Porsche realm, however due to the availability of cars and its lower entry price (for now) some people quickly sell and move on.
The 997 desirability is improving each day but market valuations have lagged due to economic disruptions (Covid/inflation). I think based of past history that the 997 generation (997.1/997.2) will dramatically increase in value over the next 10-15yrs (especially in a healthy economy). Making these 25-35K rebuilds (if done correctly Slakker/LN etc) valuable in the future.
In the shorter term the 991.1 will become the lower entry 911 and fill the current cycle the 997.1 is seeing now.
Its history, as we all know, it has a high probability of repeating itself. Im betting on the 997 generation.
(Another reason I am a bit more flexible with my overall opinions when someone is looking to keep/purchase one of these cars long-term)
