Oil Preference
#46
Are you still using Ceratec?
The look of this oil drain honestly spooked me. New oil in, and the LM is actually a bit different looking than the 0w40 M1 I've used for decades. M1 pours like "bud light". The LM 5w40 is definitely a thicker and darker pour straight out of the bottle. But the stuff that came out after 2 years and about 1500 miles (LM and Ceratec) looked like Guinness with some milk in it. Nightmare fuel.
The engine in my Cayenne ('19 model base), is an Audi-sourced 3L single turbo V6. It's a 45-degree V6 with an odd imbalance that's inherent in the design.
The Ceratec is no cure, but it does help smooth it out - there's absolutely an improvement in it. Also a slight improvement in fuel mileage.
It's not "snake oil"...
#48
The key active ingredient in Ceratec is Hexagonal Boron Nitride - or "white graphite." That is what I believe gives it a white milky-like color.
Here's a photo of drained oil (with Ceratec in it) that was on another forum related to Ceratec and the topic of how it affects the look of spent oil...
Peace
Bruce in Philly (now Atlanta)
#49
Here is an interesting description of Hexagonal Boron Nitride from a supplier (maker?):
https://www.ceramic-solutions.com/Introduction/107.html
From the link a above: "If the added amount is more than 2.5%, it can achieve high anti-wear, environmental protection and energy-saving characteristics, and even enable the internal combustion engine to run without oil, that is, to drain the engine oil, only rely on the oil film on the internal parts of the engine to resist. The compressive strength still maintains the engine and keeps it running for longer periods of time."
Wow.
Peace
Wow.
Peace
#50
I'll stick with my Motul + Ceratec. Runs quiet and drains very clean since I've been using this. Bruce let us know if you try that new stuff.
#51
Bruce,
thanks for your post. Two quick questions: do you ever do the LiquiMoly Engine Flushes ; what does your oil look like when you drain it from your engine (no pictures needed).
#52
I have used LM engine flush on Her Lexus IS250 at 100K miles and my sister's Nissan Xterra (she wasn't doing enough oil changes). Why did I do it? What did I learn? Am I happy doing it? Can you guess my answer? .... here it comes... wait for it.... I DUNNO. Why did I do it? Entertainment!!! Any comment or action I did using any of this stuff that deviates from a maker's specifications is pretty worthless. I did quite a bit of Googling about this flush stuff and didn't learn anything that was negative... same with Cera Tec... Pretty much everything out there is speculative. In short, I didn't think I would hurt anything. Oh, I do put Cera Tec in Her Lexus and now my sister's Xterra (I guess I am now maintaining her car now that I am in Atlanta).
My 5K-changed oil looks like spent oil... never looked like chocolate. I put one bottle in per oil change, this is a bit less than Cera Tec denotes to add.
Peace
TRINITONY (08-30-2024)
#53
I have no intent on trying anything new on my car as I am happy with LM 5W and Cera Tec. As is my always disclaimer, I have no science as to why I like this combo other than I do... it entertains me. My "logic" is that Cera Tec contains Moly and their ceramic (supposedly Hexagonal Boron Nitride)... moly is good and ceramic is a two-punch of goodness. Better? Better than what? I dunno.
Peace
Peace
I think the 997 holds 8 liters. So probably 1.5 bottles of Ceratec would equal their recommendation.
#54
Interesting point about Flushes. And, I'm guessing that the look of the drain oil from this oil change was affected by it being the first time for the LM 5w40 changing from the Ow40 M1. I think the first time you switch is always going to knock some **** loose.
#56
I personally think any kind of flushing is dangerous unless it’s on a fresh rebuild
flush chemicals are too strong
Wchargis2 (08-31-2024)
#57
So what i gather is that Mobil 1 is still a great oil, but DI40 may have improved on it.
#58
Peace
#59
Yea, maybe. But I could not find anything on the 'net that denoted so. I suspect the flush really breaks down oil so you only run it on the oil you are about to drain and you run for like 10 minutes only. When the oil comes out, it definitely looks different so the flush chemically reacted to whatever you had in there. When you refill, some of that flush is still in the engine albeit a tiny amount and probably already reacted/bonded to leftover oil. Honestly I have no idea what I am talking about, but again, I could not find anything wrong with flushing and both cars I used it in are running fine.
Peace
Peace
https://rennlist.com/forums/996-foru...-don-t-do.html
Raby's comment is specific to the M96 engine. I don't know if the same would apply to the M97 or not...
#60
Refer to post #12 in the thread below concerning engine flushing...
Anyone pull the heads on a modern engine using quality oil and to-spec oil change intervals and actually see sludge and deposits? I never hear of that anymore... like the old days. I did it because I thought it may clear deposits on the rings.
ALERT: Porsche dealerships offers engine flushes:
https://www.porschechantilly.com/blo...-engine-flush/
https://www.porschestevenscreek.com/...-your-porsche/
https://www.porschefremont.com/porsche-fluid-flush/
https://main-line.porschedealer.com/...sh-service.htm
Peace
