I bought a Borescored C2S Tip
Old 05-31-2024, 08:36 AM
punchdrunked
punchdrunked's Avatar
Default I bought a Borescored C2S Tip
I couldn’t help myself. Now what?
It’s a 2006 C2S TIP Cab - 98k miles. Full service history.
Sooty exhaust tips, faint tapping from the engine, but good cold oil presssure and consumption is normal. Occasional puff of white/grey smoke in start up, driver side exhaust mainly.
The question is what can I do to maintain as is until I save up the cash for a rebuild? Or use for summer and sell as is for someone else to have a go?
I’m thinking good fuel, 10w 50 oil. Fuel injector cleaner. Cat cleaner. Anything else?
Thanks for reading and wish me luck.
Old 05-31-2024, 08:41 AM
EVOMMM
EVOMMM's Avatar
Received 1,648 Likes on 964 Posts
Change your plugs and coils
i would also recommended Driven oil DI40 with ceratec
remember always warm oil by driving and always hit redline after oil is up to temp
The following 2 users liked this post by EVOMMM:
Graufuchs (06-01-2024), punchdrunked (05-31-2024)
Graufuchs
Graufuchs's Avatar
Received 1,280 Likes on 476 Posts
Driven FR50 Oil - Shortened Oil Change intervals (3K)
Driven Injector cleaner or High PEA Fuel injector Cleaner
Have you actually inspected the bores?
Sooty exhaust pipes are normal, drastically uneven soot is an issue.
The following 2 users liked this post by Graufuchs:
punchdrunked (05-31-2024), TerrestrialFlyte (06-01-2024)
Old 05-31-2024, 08:54 AM
punchdrunked
Thanks for the quick replies, guys. You’ve both recommended Driven oils, but different ones. Which would be best for my application.
Regarding the bores, I haven’t personally inspected them, the seller had and claimed #6 was in a bad way. The car idled no problem and even after starting the car, switching it off shortly afterwards and counting down for the oil level, it still read one notch down from the top and the oil pressure was good. I have a MY07 base 3.6 so know what these cars are like somewhat.
I hadn’t considered the plugs and coils but I will now.
Graufuchs (05-31-2024)
Old 05-31-2024, 08:59 AM
BillB128
BillB128's Avatar
You might want to check out this thread. If you truly do have bore scoring, the product mentioned might be worth a shot.
With that said, you've gotten some good suggestions already.
Bore Scoring Repair? Ceramic? Tribotex - wow.... - Rennlist - Porsche Discussion Forums
Old 05-31-2024, 09:56 AM
Graufuchs
Graufuchs's Avatar
FR50 (5w-50) as the 997.1 are not a direct injection platform. The 997.2 is a direct injection engine. Coilpacks/plugs are a good idea also and you can rescope the cylinders to ascertain the scoring severity. Streaking, and scuffing you can get away with for a long-time. Kudos to the seller for being honest.
Old 05-31-2024, 10:32 AM
punchdrunked
I forgot to mention that it had a few DTC’s on my Foxwell. Some were A/c related but the one that concerned me was a P0073 (ambient temperature sensor) - I’m not sure whether they’re linked but the car recently had a new water pump, thermostat and a/c regas. The 997.2 has the ambient temp sensor behind the front bumper - is in the same location for the .1’s?
I didn’t realise that the C2S had a 3rd radiator in the front. The C2 doesn’t .
Old 05-31-2024, 12:40 PM
groovzilla
groovzilla's Avatar
Received 4,853 Likes on 2,874 Posts
Buying a Borescored TIP??---->Hopefully you didn't pay more than a "roller" price of $10K for it.
Old 05-31-2024, 12:50 PM
myltz400
myltz400's Avatar
You just bought the best Porsche you could buy. Cheap and run the hell out of until it blows!
I bet you will enjoy it more than most P car owners.
The following 6 users liked this post by myltz400:
aasilvia (06-01-2024), akhbhaat (06-01-2024), EVOMMM (05-31-2024), halo777 (06-01-2024), myw (06-03-2024), punchdrunked (05-31-2024) and 1 others liked this post. (Show less...)
Old 05-31-2024, 12:52 PM
punchdrunked
I’d just sold my SLK 55 and fancied a car for the summer to run alongside my 997 C2 manual.
Boxster 986 anniversary, nah!
Cayman S 987.2, nah!
Miata, nah!
Z4m, nah!
370z, nah!
S2000, nah!
TTRS, nah!
Another SLK, nah!
And then this came up. Right on, brother. What could possibly go wrong?
Old 05-31-2024, 01:00 PM
Carreralicious
Carreralicious's Avatar
Default Good for you
Run it till it dies. I bet it’ll still go for a long time.
The following 2 users liked this post by Carreralicious:
Old 05-31-2024, 02:20 PM
EVOMMM
EVOMMM's Avatar
The severity of the scoring will determine which oil you need shoot LN engineering a message they gave answers
Old 05-31-2024, 02:37 PM
punchdrunked
thanks mate. I will do
Old 05-31-2024, 04:38 PM
yelcab
yelcab's Avatar
...the ambient temp sensor behind the front bumper - is in the same location for the .1’s?
It's the Tipt that uses the third radiator in front.
As for what's next? My Borescoring adventures - Rennlist - Porsche Discussion Forums
My 2006 997S used quart of oil 500 miles. That is when I know what's next.
Old 05-31-2024, 04:43 PM
mbatarga
mbatarga's Avatar
Replacement engine?
https://rennlist.com/forums/market/1414402
Quick Reply: I bought a Borescored C2S Tip
