Whining noise after HFPF replacement
I recently replaced the HFPF in my 67k miles 2009 T4S.
The car was showing code P1025, but was running fine except once when it went into limp mode for a while until I restarted the car.
If I cleared the code, it would reappear after 10-20 miles.
The pump replacement itself was an easy job, getting to the pump was a long process partly due to my inexperience and rusty bolts/nuts in the exhaust area (a few of them broke in the process).
I also decided to completely flush and refill the coolant system using an Airlift.
I haven't seen the error code again after the replacement, but to be fair I haven't driven the car enough yet.
But I started noticing a whining noise coming from the back. I haven't owned the car for long but I'm pretty sure it wasn't there before the pump replacement.
The pitch follows the engine RPM so it must be something that is directly attached to it.
I would be really surprised if it were the new fuel pump. But can it be? It would mean a faulty part.
The other option is something related to the coolant system. Water pump?
Has anyone experienced similar noises?
-Nico.
-Nico.
Get a stethoscope and probe around while the engine is running. You could at least isolate the noise to a major component. Water pump is easy to get a probe to.
Whining is usually something on the serpentine belt run.
4th Gear
-Nico.
-Nico.
This could also be a bad wheel bearing. This recently occurred on my 2007 997. Squeal followed RPMs and came from the rear of the vehicle in my case. I believe my back left wheel bearing went bad. Easy and cheap fix if you have access to the right equipment or an honest mechanic in your area.
Peace
Bruce in Philly (now Atlanta)
Thanks folks for your inputs.
Bought a stethoscope but nothing obvious I can hear. One observation is that I can only hear it from inside the car, not when I stand behind the engine with the lid open. Weird.
The noise is mostly audible at low speeds (20-30 MPH), at higher speeds it gets drowned in the rest of the engine, tire and wind noise.
I can also hear it when I'm not moving and I just rev the engine. Will a bad wheel bearing justify this behavior?
-Nico.
-Nico.
-Nico.
-Nico.
Odd that you can't hear it from the engine bay. Try turning off your PCM / radio. Noise still there?
Maybe, check the belt tensioner and idler pulleys. If they're worn or misaligned, they can produce a whining noise that syncs with engine speed. Also, check the condition of the serpentine belt itself.
It potentially could be a vacuum leak. A leak in the intake system or any vacuum hoses could lead to whistling or whining noises.
