Regular Maintenance Items
Old May 17, 2024 | 10:43 AM
carguy999's Avatar
carguy999
Default Regular Maintenance Items
Hi all, I downloaded a sample maintenance tracker and have been using this the last couple of years. Over time, I've added a couple items to it. Do you see anything missing from "regular maintenance" items that I should be tracking?
Old May 17, 2024 | 01:45 PM
MrMoose's Avatar
MrMoose
Water pump replacement every five years is really overkill. I'd replace the coolant every five years and not touch the water pump in the absence of any noise or leakage.
Cabin air filter is worth doing on a schedule. I test the battery at 5 years and replace at least by 7. Based on past experience I've got the gasket for the coolant fill cap on my 987.2 on a 5-year schedule but I don't know if the 997.1 has the same part.
Old May 17, 2024 | 04:52 PM
fiddlesticks's Avatar
fiddlesticks
Where'd you download this tracker from?
Old May 18, 2024 | 12:19 AM
cvalue13's Avatar
cvalue13
Would also be interested in which tracker you’re using
Sent me looking at apps, of which there are too many with roughly 4.5 star reviews
Would love to know of a good one, vouched for by members.
Old May 18, 2024 | 10:54 AM
yelcab's Avatar
yelcab
A ton of stuff is missing.
Water pump should be replaced every 60,000 miles. Coolant is automatically changed at this time.
Thermostat also every 60k miles
Serpentine belt WITH all idle bearings replaced 60,000 miles
AOS replaced 60,000 miles
Gear box oil changed every 30,000 miles (Tipt too)
Spark plugs, air filter, cabin filter, 30,000 miles
Oil changed every 5,000 miles
No mention of the IMS bearing ? Or borescope inspection ?
Brake fluid every 2 years.
Replace your coolant tank at 100,000 miles or whenever the engine is out and it's past 60,000 miles. (when engine is out, the coolant tank costs $200; with engine in, the coolant tank costs $200 plus 8 hours of labor)
That is my suggested maintenance. Waiting for things to break then replace them is reactive, not proactive maintenance for a trouble free ownership experience.
THere is no need to debate, your mileage may differ.
Old May 18, 2024 | 10:41 PM
voiceprint1's Avatar
voiceprint1
are you calling the serpentine belt the drive belt?
Old May 19, 2024 | 12:01 PM
Bruce In Philly's Avatar
Bruce In Philly
2009 C2S 199k miles
Please note: these aggressive maintenance recommendations are for .1 cars, 2008 and prior.
.2 cars are a very different machine and Porsche really upped the quality of its parts. So in my opinion, if you have a .2 car, just follow your owner manual with the following two exceptions: 1) change your oil every 5k miles, and 2) change your manual transmission fluid ever 30 to 40k miles.
Then maybe coolant and power steering fluid at 100k. And if you want to be very conservative, change your ignition coils at 120k miles when you do the spark plugs.
Everything else fails (for me at least) gracefully and won't leave you stranded.
Peace
Bruce in Philly (now Atlanta)
Old May 19, 2024 | 03:53 PM
wjk_glynn's Avatar
wjk_glynn
And for reference, the PCNA service schedule for the .2 cars…
https://rennlist.com/forums/attachme...87_2_997_2.pdf
Old May 19, 2024 | 10:07 PM
carguy999's Avatar
carguy999
I'm honestly not sure; I think I got it from here a couple years ago though at this point I've customized so much it's basically just mine. If you can remind me, I'll try to sanitize it and upload it here after making some additions based on this feedback. This is for a .1 for you guys talking about the .2.
Old May 20, 2024 | 10:06 AM
carguy999's Avatar
carguy999
Great tips. Some of these things I am adding into my "regular maintenance" cadence and some of them (like the coolant expansion tank) I think fall under "while you're in there" stuff and so I wouldn't necessarily be tracking those. Some are one or two-and-done over the life of the car, and for me personally have already been done.
I went through this list and marked green things that I am going to add, yellow were already accounted for in the list, and red I am considering "as needed" or so infrequent as to not need to include in a running tally of things to keep track of. This isn't my only tracker; it's just the tracker for regular or semi-regular things that need to be done.
Old May 20, 2024 | 03:56 PM
fiddlesticks
Appreciate it nevertheless, could build my own tracker based on this and the additional comments on here too. Good stuff!
Old May 20, 2024 | 06:38 PM
carguy999's Avatar
carguy999
Hm, it doesn't seem like I can upload an Excel file here - I have put a cleaned version out here for now: https://file.io/CePBJfS3K3yT
You'll have to play around a little bit with some of the calculations since when I deleted some of my info I think some dependencies may have broken but this should mostly work!
Old May 20, 2024 | 06:39 PM
carguy999's Avatar
carguy999
Well, I guess it did attach but it wasn't obvious when I was posting. I'm going to remove the file.io link so don't use that; both of the attached files above are the same
Old May 20, 2024 | 08:24 PM
groovzilla's Avatar
groovzilla
Not sure if I saw Idler Pulleys with the belt replacement^ Idler Pulleys nasty and loud when worn out at 60-70K miles
Old May 21, 2024 | 10:18 AM
carguy999's Avatar
carguy999
No, good call, it's worth calling that out separately. For me, if I were replacing a belt, I'd at least inspect the pulleys at the same time so for my personal tracking I didn't include that.
