Question----> Can the "S" Brakes be installed on Non-"S" 997?
Friend was asking so thought I'd ask the wrenches on the Forum.
Can the larger "S" brakes be installed on the non-"S" 997?
EMC2 has done it:
Brake Caliper Refinish DIY with VHT Paint & Caliper Upgrade on 997.2 C2 Base
https://rennlist.com/forums/997-foru...2-c2-base.html
Not for a 997.1, you need the S hub carriers for the front.
The 997.2 can accept the S calipers.
groovzilla (04-26-2024)
997.2 can for sure as I did it. Only requirement was different caliper bolts iirc and appropriate rotors. Just can’t remember if the donor was a 997.1 or a 996 variant
Thanks!
Graufuchs (04-26-2024)
