Which 350mm Rotors do we recommend
#33
I didn't need any kind of spacers. The rotors and calipers are both from the 997.1 PCCB setup. I just looked at the 997.1 GT3 PET, and looks like the same part number on the caliper bolt, 85mm. Maybe i'm missing something though
#34
so weird, i ordered both sets of studs so ill test and report back when the time comes!
Only difference i can see is that you’re PCCB calipers and i’m using non pccbs? idk!
monochrom3 (03-27-2024)
#36
Anyone need a pair of 6 pot calipers that bolts on directly without the need for any adapters? They are not as common as the 225mm wide 6 pots.
142mm 6 pot front calipers
