997.1 oil leak
997.1 oil leak
I was inspecting the drain bolt (to see if it was the magnetic one or OEM) this morning on my new-to-me 2005 C2S (76k miles on it) and noticed a small oil leak. When I had the car PPI'd recently, they noticed the oil pan was leaking so they replaced the gasket and did a fresh oil change (probably why the oil is still golden). I've searched online to see what could be the cause and the fix, but i'm mostly finding info on oil leaks from the rear main seal - can't find anything on this location. Can anyone provide some guidance?
Petza914 (11-25-2023)
It looks like common green antifreeze when it should be "pink" (Porsche/equivalent) antifreeze.
Has the water pump ever been changed? The consensus is that they should be changed on a 60000 mile mileage schedule. Change to a low temperature (160 degF) thermostat at the same time. Try to flush all the old coolant out during the maintenance process, or plan to do multiple drain, drive, and refills with distilled water.
Gasket at the Coolant pipe connection most likely needs replacing
It didn't feel oily but the color threw me off. Thanks!
I don't believe it had been replaced so it's about time. Thanks for the heads up!
Thanks, I'll look into this along with the water pump.
Also important to use Porsche coolant only. If you ever need to top off coolant tank temporarily only use DISTILLED water.
So I haven't had much time to look into this and today I went under the car to check again, and saw even more coolant leaking. It looks like there is a very slow drip (I saw a drip just as I went under the car). FYI the car hasn't moved since last time as it's parked for the winter.
It obviously looks like the gaskets need to be replaced, but why would the other gasket start leaking if the car is just sitting? Temperature change? Also I'm trying to find the specific gaskets for these locations - what keywords should I be searching? When I look up info on coolant gaskets, all I'm finding is waterpump and thermostat gaskets. I don't know that specific names I should be searching. Could this be linked to some other sort of cooling system issue that I need to look further into?
That is because the gasket is not leaking. The water pump is leaking from the shaft seal, which is above both of those wet spots and the coolant is just showing up at the bottom. The cure is new water pump, and new thermostat, both of which would need new metal gaskets.
jchapura (12-08-2023)
If your Indy Mechanic allows you to purchase the OEM parts, I suggest buying from Sponsor Rennpart.com. They have excellent pricing/inexpensive super-fast shipping.
I've been buying OEM partsd from Rennpart for years and years.
How many miles on car? Do you have service records for your car? If not, it may be wise to have the Idler Pulleys & Belt changed as well. They seem to wear out at about 60-80K miles. Worn Idler pulley bearings get loud at higher RPM's.
Also if not performed have coils/plugs changed - Basically a major service if no indication the work has been done.
https://rennpart.com/
When you replace the water pump also replace the Thermostat. I assume that hasn;t been replaced?
Around 76k miles on it. I have some of the records but not all of them. Just got the car recently and pretty much went straight into winter storage. I'll take the car to the Indy mechanic and have them inspect all those items and get done so I can enjoy it come spring time! Thanks for the heads up!!
Many owners sell their car before performing the heavier maintenance. Also true with Mercedes.
At about the 75K-90K mile mark Idler Pulleys/Belt/Water Pump/Thermostate need changing out.
*If you didn't perform a PPI, also have indy shop check Coils & Plugs/Brakes/etc & Coolant flush. Of course oil change as well.
Also good idea to have battery on maintainer like the CTEK model. Stays plugged in and keeps Battery in good shape.
All the best.
