can you code out PASM ona 997.2 ?
Can you code out PASM on a 997.2 car if you fit some Ohlins, or do you need a £400 Cancellation Kit still.
There are small modules to delete PASM:
https://www.urotuning.com/products/k...BoCJT0QAvD_BwE
But you can code it out as well.Reply
https://www.6speedonline.com/forums/...pro-works.html
I don’t really want a lot if I can avoid it. Rather code it out.
mrd_spy (09-06-2023)
Curious why you would swap an active suspension system for a static one.
Ride height? Or do Ohlins provide better compliance and performance? Or just performance gains?
Seems like a bad trade for a street/canyon 997, but I am all ears.
Active is too slow and unpredictable I find, gives a very bumpy ride and PASM on the nose bobs about, it’s pretty ****.
passive you know where you are and all the ring records done by Porsche on on passive dampers you will note.
I'd have agreed with you before I installed a DSC controller, they're pretty much magic. I'd recommend that you consider installing one before you start chasing other options unless you really want to spend more money.
Liste-Renn (09-08-2023)
