Fluid leaks??
Fluid leaks??
Weird. Had what looked like an engine oil leak about a year ago. Not much. Maybe 2-3 tablespoons on the garage floor. Took the car to the indy and they couldn't trace it and the garage floor has been bone dry ever since. Then Friday last week, same thing again. Same small amount of what looked and felt like engine oil. But then, I don't know how to tell the difference between engine oil and PDK fluid.
Just like a year ago though, the Friday leak was it. Not a drop on the floor since no matter what kind of oil it is. But to add to the mystery, when I was gone, my wife found a small amount of pink fluid underneath the engine where my car is parked in the garage. Still no more engine/PDK looking fluid though. No alerts on the dash and the engine oil is topped off. Checked it yesterday afternoon. Just had an oil change so did they overfill? Any ideas anyone?
Was the coincidence brought about by the same underlying issue? I would guess no.
The easier of the two to track down may be the coolant leak. Seems like there is always a telltale sign somewhere when those happen. I would go after that one first.
The oil (?) leak is a little bit more perplexing. Small amount. Then nothing for a year. Very odd. Were there any common factors that precipitated the two leaks? For example the car being driven particularly hard those times?
Nothing like a "fluid mystery" to brighten one's day! And now two of them to ponder about.
Was the car driven harder than usual before the oil drip events, like in a group drive or mountain carving session? I had an issue years ago where my case halves would leak a little oil, but only after the car was driven pretty hard. Tool out each case half bolt one at a time, cleaned the hole and threads, put some sealant on the bolt, put it back in and torqued to spec and has never dripped again since.
Coolant leak - check the reservoir for vertical lines after driving the car and it getting hot and up to pressure and the water pump weep hole as those are the likely culprits.
