Quick Help on Torque Specs
Does anyone have the torque specs for the transmission to engine bolts? I will be damned if I can find them anywhere. If there is a good thread/location for all specs that would be awesome because I am sure I will need more.
Jake has a book that gives all torque specs as well.
63 ft lbs. Source: Jake Raby's Fastening Specs for the 997 booklet. You need this.
The OP did not list which he has. Best to get the book and see locations.
Ahhh didn't know that...i wonder why there are three different manual transmissions 😅
I do not have a complete set of specs for all the nuts and bolts so I just use fastener bolt grades and shank size to come up with a torque that will be good enough. You are at this long enough, you will develop a feel for when it is tight enough. Not everything needs to be done at 1% torque accuracy (never is).
