Brake question - 997.2 C2
Hello, I recently picked up a super nice 997.2 C2. Love the car, and it has good maintenance records. Only problem is a brake pulsation at higher speeds, like a warped rotor. It had new front rotors and pads about 15k miles ago and new rear pads (but not rotors) about 10k miles ago. The front pads look to have maybe 50% life left and the rears look 80%+. Seems odd that the brake pulsation would be from the front rotors if they were replaced 15k miles ago, but could be possible. Could a rear rotor be warped and causing the pulsation? I've only ever had front rotors cause a brake pulse.
Should I replace the front rotors first? I've always heard that you should replace pads with new rotors, so would do both. Or should I replace the rears first since the front rotors are only 15k miles old? The rears look nearly new though so don't like the idea of replacing perfectly fine equipment. Or do I just replace all four corners with new pads and rotors and call it done.
Also, what do you think of the brake kits from Pelican - comes with Textar pads and Sebro rotors with all the necessary hardware, are those good quality? Or better off going with genuine Porsche parts? This would be for street use.
Check out FCPEuro, no affiliation, free shipping ovef $49 and lifetime replacement.
And for DD with no track time Sebro and Textar should be fine
Hi,
the pulsing can occur from uneven brake pad material deposits on the rotors, this can be caused by incomplete brake bedding in, before going full race mode..
it is possible to clean the buff/sand brake material deposits off using power tools.
Or....... take it back to the shop.
Petza914 (09-01-2022)
I wouldn’t replace anything until you figure out the cause. You could have a caliper problem that will not go away after you spend all that money.
Also, a bent wheel can cause a pulse while braking.
Thanks all for the feedback. The pulsing tends to be worse after the brakes are warm, and really only noticeable above 50mph or so. I noticed the rear rotors are worn and have a definite lip on them - I am assuming the rear rotors have never been replaced. If I am going to take the brakes apart, I would just go ahead and replace pads and rotors. It has fresh fluid. I'm thinking about upgrading to Porterfield R4-S pads and new Sebro rotors on all four corners. That seems like would be a nice upgrade and support some spirited street use better than stock pads. What do you think?
Basic Sponsor
I loved the RS-4's on the M3. When the time comes to replace my textar ones i will go with them!
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
Hi,
