New Head Unit Second Time
- New Android head unit;
- Enfig microphone; and
- Replacement of the sticky climate control buttons.
With the initial PCM upgrade, the installation removed the OEM harness and replaced with a different one from Euro Motor Speed. Installing the current head unit was a slight challenge as the the new head unit was a plug and play with the OEM harness.
Considering the OEM harness gone, this was an interesting activity. A bit of wire colour education and soldering, very pleased with the system.
Also purchased and Enfig microphone that is placed inside the steering column where a microphone slot already exists. Excellent result.
Lastly, replaced the sticky buttons.
C$ 199.15 43% Off | Multimedia Receiver Android 10 Player For Porsche Cayman 911 Boxster 997 CAR GPS Navigation Receiver Auto Stereo Radio Head Unit
https://a.aliexpress.com/_m0P5Ah6
https://enfigcarstereo.com/ENFIG_MIC_POR1.html
C$ 21.96 17% Off | Climate Control HVAC A/C Button Set For Porsche 997.1 Carrera 911 Targa Turbo ( A PAIR )
https://a.aliexpress.com/_mMf0ZEs
New head unit appears to be a similar look as the PCCM.
Also, I have the stock base unit with no CD changer- would this be plug and play? The fit is a bit off at the bottom sides or is that more just photo distortion?
The head unit is Android based and the software installed called TLink and provides an IPhone wireless Bluetooth connection. Also has software for AndroidAuto for Android based phones, but may be wired. I use IPhones, so the wireless works with the new head unit.
The new harness should work, but if you have a Bose fibre optic, you would need a converter. Should be plug and play, but contact seller to confirm as they may have different harnesses for different applications. My installation was different as the OEM system was removed.
There is a slight overhang on the bottom sides, but is hardly noticeable.
