GT3 350mm brake kit for 2010 base Carrera
I have a 2011 997.2 base Carrera. About 6 years ago I did a brake upgrade and sourced used 997.1 turbo brake calipers and rotors from LA dismantlers. They bolted right on without spacers. Only modification needed was brake lines from the hub bracket to the caliper which was pretty easy. Lots of brake line kits available. Also needed longer caliper bolts to reach the hub due to the larger diameter 350mm rotors. I don't recall what the bolt spacing was but remember it was different than the 997.2 carrera S and the same as the 997.1 Carrera S. And obviously the same all around as the 997.1 turbo. I also believe the 996 GT3 front was the same but not the rear.
The 997.2 base brake system is shared with 997.1 911 Carreras and various Boxster/Caymans. Examine the fitment lists for calipers and rotors:
https://www.gaudinporscheparts.com/o...ly-99735142100
https://www.sunsetporscheparts.com/o...or-99735140101
https://www.sunsetporscheparts.com/o...per-9p1615123h
Basic Sponsor
If you don't want to buy an assortment of mismatched parts from different vendors and try to piece something together, we have some fantastic and complete brake solutions for the 997 Base (and other trim levels). Our systems are thoroughly engineered and come complete with everything you need in one box. Our systems are larger than the OEM GT3 setup, they are better performers, and they are a completely bolt-on affair with simple hand tools. We have two different types of complete brake kits, Competition and Road. Our systems are designed to properly replicate the OEM brake torque at both ends of the car, so you don't have to worry about fouling up brake bias, ABS intrusion, etc. Our Competition Kit uses a 372x34mm front disc and our Road Kit uses a 380x36mm disc. If you don't want to invest in all four corners, some owners just go with our front Road Kit in black or red paint to match their rear OEM caliper color. Then they either run a 2-piece rear disc or factory rear disc. The fronts tend to take far more abuse, so that's where the greatest ROI is.
Full menu of AP Racing options for the 997.2 Base is here: https://www.essexparts.com/my-vehicl...02/Iron%20disc
Our menu for the 997.2 S, GTS trims here (we offer 2-piece AP Racing Discs to work with the OEM calipers for these trims): https://www.essexparts.com/my-vehicl...2S/Iron%20disc
Some recent 911 customer pics below, and you can see tons of Porsche owner reviews (and others) on the Essex Blog
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
