GT3 350mm brake kit for 2010 base Carrera
Hi, I have a base 997.2 in need of rear brakes soon and I am contemplating upgrading to the OE big brake kit that Suncoast offers. I would also do the front brakes although they are 2 yrs old. Have owned this car since new and now at 145k miles. Looking for improved braking, but not for tracking. Just a daily driver. Read in the Suncoast site that this upgrade is only for 996 Turbo, 994 Carrera 4S 2002-2004, Carrera S 997.2 and Carrera 4S 997.2., so only for wide bodies they write. But the Carrera S 997.2 is not a wide body as far as I know. Anyone have any knowledge of this kit fitting a base Carrera 997.2? If it fits a 997.2 Carrera S, why not a base 997.2? Here's the link, hope it works for you.
https://www.suncoastparts.com/product/6Piston.html
Stock 997.2 base brakes are more than enough for street driving. Beyond perhaps a coat of paint to freshen the calipers up, really don’t see the need. I’d put that money in the (few) areas a 997.2 base car could use some help; reducing the 4x4 ride height, improving the stock exhaust note, and tightening up the shift feel if you’re 6MT.
preelude (07-30-2022)
The caliper bolt spacing is different between the 997.2 base Carrera (130mm) and the other cars cited (142mm). More aggressive pads and a good fluid bleed would get you improved performance for the street.
Best call Suncoast to clarify about their kit. They are usually very helpful and knowledgeable. What kind of “improved braking” are you looking for? Your stopping distance will not change with the upgrade. Depending what you are after, there are other upgrades like the GT3 master cylinder and GT3 brake booster you might consider also.
Front:
https://flat6motorsports.com/product...rera-carrera-4
Rear:
https://flat6motorsports.com/collect...rera-carrera-4
As others have stated, the .2 brakes are great to start with. I am considering the Girodiscs myself along with Hawk Ceramic pads to minimize brake dust.
Kuhl997.2! (08-01-2022)
Girodisc makes 350mm 2-piece rotors that come with caliper spacers for our cars:
Front:
Rear:
Front:
Rear:
The following 2 users liked this post by 850tgul:
Frank 993 C4S (07-30-2022),
nwGTS (08-02-2022)
My opinion on what to do ,I will keep to myself. However, for those reading this thread for info, etc, you should know that the OP has a .2 base car. The brake system on these models was a brand new set up and design by Porsche. Do not think that it was a carryover from .1 cars. Part numbers will get confusing if you don't keep track of this.
preelude (08-02-2022)
Hi, I have a 997.2 Carrera 2S and I upgraded my brakes to front 350 mm rotors with the 997.1 GT3 6 piston calipers with 142 mm distance between bolts (same as 996.2 GT3).
If you have a 997.2 base Carrera your rotors are 330 mm and 4 piston calipers with same distance of 142 mm, so you can do the same upgrade.
As for better rotors I used zimmerman 350 mm at first (enclose photo) with brembo pads and the braking improved a lot. Nevertheless I changed later to DBA rotors 350 mm front and stock 330 mm rear (enclosed photos) with pagid pads and it breaks way better now.
Alternatively if you prefer not to change the stock calipers your best option is Girodisc just
997.1 GT3 calipers
because you will need spacers and theirs are the best..
Hope I have been of help
Cheers
Andrés
997.1 GT3 calipers
Cheers
Andrés
In addition to my previous post. True that GT3s (both 996.2 and 997.1) have a different offset of wheel hub and rotors matching each other. But it does not affect the calipers. You have to use the 997. 2 turbo rotors 350 mm that have the same wheel hub offset than the base Carrera.
https://www.gaudinporscheparts.com/o...ly-99735142100
https://www.sunsetporscheparts.com/o...or-99735140101
RABjr (10-11-2022)
The sunset link definitely proves my point, the .1 911 is not listed. It cannot be , different size. The Gaudin link for caliper leads one to believe that there is no sense in "upgrading" brakes on a .2 base Carrera since you already have GT 2RS brakes.
