Why not to add MoS2 Moly to your oil?
Old 07-14-2022, 09:17 AM
silver_tt
silver_tt's Avatar
Originally Posted by Carreralicious
When I got my Boxster back in 2002, I followed the manual which recommended an oil change every 15K miles or every 2 yrs until Porsche changed that to 10K miles and then I followed that. LOL. I still had the car for 17 yrs and never had any engine problems and a friend owns it now and it’s still running great. Only used Mobil 1 0W-40 and no additives. I’d think your two blown engines would have blown even if you added Ceratec or MoS2 but that’s just me. I mean, why add anything solid (even if a lubricant) to an engine that is supposed to have liquid in it? Maybe, they might have blown earlier. 😆
FYI if you don't already know the history, M1 0w-40 used to be a great oil. I also ran it many years ago back when it was a good oil.
The beginning of the end was not long after the Exxon merger....and, of course, the famous M1 v Castrol lawsuit regarding the use of non-synthetic group 1-3 base stocks (not group 4 PAOs and 5 esters) and still being able to market it as "full synthetic". It's not the same but it was ruled that it was ok to market it that way.
IMHO for several reasons it's not really apples-to-apples to compare a oil today to what it was ~20 years ago. Environmental regulations alone have changed the composition of oils significantly over this period of time.
lkraav (08-10-2022)
Old 07-14-2022, 09:26 AM
Carreralicious
Carreralicious's Avatar
Yes, but those things happened in 1999, and my car was in my possession from 2002 onwards. Same thing with MarcW’s 2002 Boxster that he bought new and drove for over 250K miles.
Old 07-14-2022, 04:43 PM
ATX_Native
ATX_Native's Avatar
I see mentions of DT40, is DI40 the best bet for the 997.2 DFI cars?
Old 07-14-2022, 05:07 PM
silver_tt
silver_tt's Avatar
IMHO Yes. If you go with a Driven oil, DI40 is for the 997.2.
DT40 is for 997.1 port injected engines
DI40 is for 997.2 direct injected engines
ATX_Native (07-14-2022)
Old 07-14-2022, 05:16 PM
Petza914
Petza914's Avatar
Received 6,597 Likes on 4,195 Posts
Yes, as silver_tt says, but I actually use DT40 in my DFI Cayenne Turbo S so I don't have to stock another type of Driven oil and the UOA reports are stellar, so I think you can really use either one.
Old 09-10-2023, 03:33 AM
Audi Junkie
Audi Junkie's Avatar
Excess moly leads to valve deposits.
Old 09-10-2023, 09:46 AM
silver_tt
silver_tt's Avatar
It has been shown that adding MoDTC to oil can cause coking/deposits in turbochargers (very high temps and pressures) as they act as a decomposition catalyst. However if the oil chemistry is right you don't need to worry about this. I have been running DI40 for over 50K miles in a turbocharged engine -- it was designed for it. Even running XP9 which has a ton of moly, zero issues.
Old 09-10-2023, 10:08 AM
Petza914
Petza914's Avatar
I'll take fairly easily cleanable valve deposits over scored or worn internal engine components all day.
The following 2 users liked this post by Petza914:
EVOMMM (09-10-2023), Graufuchs (09-10-2023)
Old 09-11-2023, 12:22 AM
FlatsixS
FlatsixS's Avatar
Originally Posted by 997.1C2S
First time user of ceratec in my last oil change. Under load at mid-high rpms the engine sounds and feels noticeably smoother. 17+yrs in the auto industry and like to think I have somewhat of a trained ear, HA!
Like Bruce I plan to alternate ceratec and Mos2 on my C2S 997.1.
same here. I used Ceratec for the first time last oil change (performed last February). I’ll do oil analysis (blackstone) every oil change. So far everything is good, like to see next oil change oil results just for info. I’ll alternate between the two additives. BTW, seems that the oil dilemma is like discussing “taste and colors”… and eternal theme of discussion, never ending
Quick Reply: Why not to add MoS2 Moly to your oil?
