Still leaking coolant from right below alternator
Old 06-29-2022, 08:31 PM
chonniedotcom
chonniedotcom's Avatar
Default Still leaking coolant from right below alternator
Still leaking coolant after replacing the gasket below the alternator. :-(
Any ideas what else it can be?
It’s dry left and right of the alternator.
I am at a loss.
Old 06-29-2022, 11:53 PM
jchapura
jchapura's Avatar
It could be a defect in the mating surfaces. It could be the installation.
Isolate the exact spot it's leaking.
I would dry the area completely (perhaps rinsing with water and then using compressed air or air dryer).
Then pressurize the coolant system system to around 16psi (while engine is cold).
Watch for the leak. Mark the spot(s).
Disassemble.
Inspect the mating surfaces. Clean up any defects.
Consider using a "smear" of RTV along with the new gasket. (Be sure there's no "squeeze" excess that can break off and circulate in the coolant system.)
Respect any specified bolt tightening sequence. Respect the specified torque.
Respect the cure time before applying pressure (whether from being pumped-up or from the engine being started and warming up).
Old 06-30-2022, 09:01 AM
Petza914
Petza914's Avatar
Received 6,258 Likes on 3,984 Posts
Disassemble.
Exactly this. When I installed a new plate there, I smeared some gasket sealer on the gasket - it's just a smear, so a very thin coating along both sides. I do the same when installing water pump gaskets. You can see it in this photo - it's the plate behind one of the supercharger brackets. You can also see there's a hose clamp connection on the right side. Make sure the clamp is tight and that it's not just leaking from that connection.
Old 06-30-2022, 02:08 PM
chonniedotcom
Thanks. I did not use RTV. Maybe should have. :-(
I will give it another shot with that.
Thanks.
Old 06-30-2022, 09:08 PM
chonniedotcom
Our alternator’s are not water cooled are they?
2007 3.8 S Cab. ;-)
Old 06-30-2022, 09:11 PM
Petza914
Petza914's Avatar
2007 3.8 S Cab. ;-)
No, they are not.
Old 06-30-2022, 09:22 PM
chonniedotcom
No, they are not.
Thanks. ;-)
Old 07-09-2022, 11:33 PM
chonniedotcom
Default Solved the leak.
Finally.
I redid the gasket with RTV and it started leaking worse. I was like WTF? Noticed that it was dripping from the top right bolt. So the next thing up from that was the small rubber hose. So I decided to take that off and replace it with a new piece. When I looked at the hose I could see signs of pink dried antifreeze about half way up on the backside.. It must have had a small pin hole leak. After swapping it out with a new hose, I have now driven a few good healthy stomps and have not seen any more leakage. ;-).
Cracking a beer to celebrate.
Hope this may help someone in the future.
The following 3 users liked this post by chonniedotcom:
anewman (07-10-2022), Chalkboss (07-10-2022), TerrestrialFlyte (07-10-2022)
Quick Reply: Still leaking coolant from right below alternator
