found this part loose under the carpet, under the cabrio roof storage area (while filling up some hydraulic fluid for the roof mechanism) on my 2009 C2S 997.2
Problem is, I can’t find the part in the parts catalog nor anywhere on the web?!?
Am I simply just reading it wrong?
Any ideas where it should go?
My catalog has one number different... for a grommet used for the airbox. I have removed my airbox, and inadvertently popped them out having them drop to the ground. Just maybe. You could remove your airbox and take a look.
For drainage grommets, they usually have a slot cut in one side to allow water to drain... usually.
Peace
Bruce in Philly (now Atlanta)
