997.2 Non-Turbo Front Indicator Removal
Is the procedure the same as a 997.1 for the 997.2 front indicator on an N/A model? I see people using a hotel key card and a trim puller on YouTube, but don't want to start yanking until I know that should work on the 997.2 non-led front indicators. Hope its not a bumper off sort of job. My right bulb or connection is bad. Thanks!
If you’re referring to the daytime running lights on the 997.2, the front bumper unfortunately needs to be removed in order to swap them out (unlike the key card trick on the 997.1).
If you’re referring to the side markers, those can just be pulled straight out (rearward) via the wheel well without removing the bumper.
