What's This Noise?
On a recent trip to the "Tail of the Dragon" my car made a bad squealing noise from the front right corner, but only after hundreds of hard turns and only under hard braking. I had the same thing happen one other time during the trip, also on a hard left turn. The noise stopped when I backed off. Thoughts?
J-Lung (05-05-2022)
The following 2 users liked this post by hbrakes:
Hella-Buggin' (05-05-2022),
J-Lung (05-05-2022)
Do you have non-OEM brake pads? If so, you'll need to re-bed them
https://pages.ferodoracing.com/produ...s/pad-bedding/
J-Lung (05-05-2022)
Thanks guys - I was thinking it was the brakes, but not sure why it only happened after a lot of repeated build up. I had somebody else suggest the sound is like rotor flex touching pads. He suggested I check the wheel bearing for play.
What causes the noise is oscillation between the caliper piston and the back of the brake pad carrier. To eliminate it you'll need to do something to restick the pad to the caliper pistons either with new OEM pad dampeners - these are the adhesive rubber pads with metal prong that lock them into the caliper piston or with a liquid anti-squeal product from CRC or Permatex.
2009 C2S 179K miles
Sounds like a classic hot brake. When I first tracked my car, I was freaked by the noise... you almost never hear that squeaking and grinding and metal-on-metal awfulness on the street. To test this out, you can make your brakes get hot on the street by finding a road and do rolling hot accelerations and hard stops. You can get them hot enough to squeal. There is nothing wrong with a squealing hot brake. It is what they do.
Peace
Bruce in Philly (now Atlanta)
Peace
179K miles with track experience! Thank Bruce for the feedback. I was thinking it could be a hot brake squeal . . . I haven't tracked the car, so haven't heard that noise before. In thinking about it, on public roads, I feel I can take a left turn harder than a right, since a head on collision could result if I over cook a right as opposed to an "off" with a left. Not good to overcook a turn either way I guess . . . .
If he runs racing hardness pads, then the above doesn't apply and then it's just normal brake pad noise from those super hard pads designed to work optimally and high temperatures, but if running racing pads, he'd likely know this already and the speeds in the video aren't high enough to create that kind of heat, especially with the acceleration time between corners
J-Lung (05-05-2022)
Sorry, but I disagree. The reason brakes squeal is because of oscillation. It's usually race car brakes that we're used to hear do it so we correlate hot track brakes to the squeal noise, but it's because those pad compounds are much harder so they oscillate more than street compounds. If street pads are squealing, it's because the vibration dampeners are no longer working and to get street pads hot enough to squeal like race pads, the car is either on a track or the driver is over-braking the car. Street cars brakes don't start making noise even when running ridiculous speeds through Tail of the Dragon and similar curvy mounting roads. If they've gotten hot enough to make that noise, they're now glazed and regular braking will be compromised until that super hard fused layer is removed.
