Does OEM Porsche 997 rear wheel arch trim cause RUST ?
Rust is appearing in the rear wheel arches under the OEM rear wheel arc trim ( the plastic part is in front of the rear wheels pictured below) on my 2006 997 coupe . The part traps dirt and moisture.
I wanted to ask the forum if it it a aerodynamic part needed for car stability or rear brake cooling ?
PCA tech told me that it’s purely decorative.
I wrote to Porsche USA - they told me to ask my dealer -my tech at my dealership ( excellent dealer) is also unsure- IMO only the factory would have a definitive answer so I have asked Porsche USA 3x to forward my question to Porsche Germany. After I get the rust fixed I will only replace the part if it is functional. I will post a response( hopefully from Porsche) so other 997 owners will know Best to all ! Russ Dejulio Pittsburgh PA
A picture of the replacement part is below
Thank you !
Russell Dejulio
Pittsburgh PA
Thank you !
Russell Dejulio
Pittsburgh PA
russm535il (04-28-2022)
thank you Best ! Russ
Thank you yes that’s what I thought however I checked with PCA Tech and they said the part was purely decorative . I have asked Porsche USA customer help to ask someone in Germany I hope that they can give me a definitive answer . If they serve no function I will remove them .They have trapped a lot of dirt and moisture there causing rust
Russ
I removed mine to clean behind during some other maintenance last fall. I can confirm this is also an issue on the 997.2 (2009 C2S) the mess collected behind there would have caused rust if I hadn't cleaned it out. The amount of stuff caked in there and it was still moist... The stuff in the lower right was about 1/4 in thick - the stuff around the sensor was dry - that is also covered by the piece.
PSA: remove them and clean behind them before you have an issue with rust. I've added this to my pre-season clean-up process.
The following 2 users liked this post by voidopolis:
russm535il (04-28-2022),
VT Blue (05-31-2022)
russm535il (04-30-2022)
They are aerodynamic part to prevent air to flow directly to tire and create drag (and often lift too). Almost all manufacturers have these in front of tire on all 4 corners, some just plastic flap mounted to body or part of wheel splash guard extension and some style it (like in 997).
Auto manufacturers never/rarely put parts like these (underbody parts) without any function as we are all under cost, weight, fuel consumption and emission pressure. How do I know this? I work for a major Auto maker in Aero/Thermal Computation Fluid Dynamics area. From my estimate these parts usually worth 0.002 or more with wider rear hip/tire in aero coefficient of drag reduction.
The following 2 users liked this post by laphan:
BmacIL (04-30-2022),
russm535il (05-03-2022)
Answer to arch turn function
I wanted to close this out with the answers I received in regard to this parts function on a 997 .
I received answers from PCA Tech Excellence magazine tech and my local Porsche dealer Service Manager.
The trim serves no Aerodynamic function It is mainly decorative and protects the car body from rocks picked up by the rear tires
My dealer is going to replace the trim because they told me that rust was on the part ( I assume screws clips that hold it on ) but luckily not the body of my car .
Thank you for everyone’s input !
Best !
Russ Dejulio
Pittsburgh PA
Best !
Russ Dejulio
Pittsburgh PA
